Centrifugal pump
Old   October 22, 2014, 06:52
Default Centrifugal pump
venkat
svenki7 is on a distinguished road
I am working on Cavitation in Centrifugal pumps. I have experimental data for discharge(l/s) and Total head (m). First I am matching Head vs Discharge graph in steady state for single phase flow (water, with out cavitation).
My Boundary conditions used:
Inlet: Mass flow
Outlet: Pressure Outlet
RPM: 2000
But for above boundary conditions Head is not matching.
Another trail:
Inlet: Pressure Outlet
Outlet: Mass flow
RPM: 2000
But for above boundary also conditions Head is not matching.
I saw some publications on pumps. Most of the authors used above boundary conditions. I am new to this area.
Can you suggest me boundary conditions for getting Head Vs Discharge graph.
Any help will appreciate .
Thanks in Advance
Venkat
svenki7 is offline   Reply With Quote
Old   October 22, 2014, 13:57
David Stanbridge
swiftaircraft is on a distinguished road
A you using the Sliding Mesh Model or one of the others?
David Stanbridge
Swift TG Solutions Limited
www.swifttgsolutions.com
swiftaircraft is offline   Reply With Quote
Old   October 28, 2014, 09:46
venkat
i am using MRF (moving reference frame).
Old   May 24, 2016, 02:22
Mehmet Kaya
mhmt is on a distinguished road
You can use mass flow inlet and static pressure outlet BCs but make sure that your calculation domain is extended enough at the pump inlet and outlet.
If this is not the case, the outlet BC can detoriate the pressure field and lead wrong inlet presuures.
mhmt is offline   Reply With Quote
Want Impeller Driven Fluid Flow: What Inlet and Outlet BC to use for Centrifugal Pump Zev Xavier FLUENT 3 May 9, 2016 06:42
centrifugal pump Chalghoum CFX 18 April 16, 2014 06:37
Autoblade centrifugal pump template mahdi balali Fidelity CFD 3 February 18, 2014 08:56
centrifugal Pump Efficiency A.farid Main CFD Forum 0 March 31, 2012 07:39
Centrifugal Pump Cavitation problem or not. ismael.s CFX 13 February 27, 2012 08:00
