On the Courant number .
Old   May 4, 2003, 22:10
Default On the Courant number .
raintung
Hello everyone, When I use fluent to simulate 3D flow field, I set the Courant number 0.5 at the beginning of the iterating. Later, once I increase the Courant number, the following information appears: divergence detected - temporarily reducing Courant number to 0.2 and trying again... What should I do? If I don¡¯t increase the Courant number, convergence become slow, and I don¡¯t know whether this will affect the computation results. Thank you!
Old   May 5, 2003, 04:25
Default Re: On the Courant number .
Holidays
That the simulation slows down is pretty normal as you are relaxing the solution more, not allowing it to changeso much at each iteration. Cr number criterion are usually good to get the simulation going; later on you may want to change to a less stringent condition.
Old   May 5, 2003, 08:11
raintung
Thank you! But what does the stringent condition mean? I know I set the low succssive ratio(spanwise), because I want to obtain the streamline distribution on the endwall(there is a thin fence on it). How can I modify this? Thanks.
Old   May 7, 2003, 06:03
Holidays
What I meant is that later on, when you start converging, you should change for a "physical timescale" in place of the Cr number approach so that the solution can continue going, but at a faster pace.
Old   June 2, 2016, 12:26
bilel
bilel is on a distinguished road
Divergence detected - temporarily relaxing and trying again...
bilel is offline   Reply With Quote
Courant number fireman FLUENT 7 September 11, 2021 11:33
IcoFoam unstability, courant number gets large! vivien OpenFOAM 11 March 9, 2017 03:45
LES near wall model & courant number kasim CFX 5 March 16, 2008 18:23
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Courant number calculation - unsteady flow Kuba FLUENT 0 November 8, 2005 22:44
