Monitoring convergence by pressure drop in fluent |
November 24, 2014, 11:13 |
hamid
Rep Power: 11 |
Hi everybody,
How can monitor convergence by the pressure drop value in fluent? Actually how can define pressure drop value for monitoring and what is the criteria? Thanks in advance for any help. |
November 25, 2014, 03:49 |
Rep Power: 15 |
General comment: Using pressure drop solely isn't a good choice of convergence.
But let's say you know the exact value of pressure drop in your domain (from experiment maybe!). What you can do is defining two different planes (or 2 lines if you are modeling 2D) on the levels where the pressures are known. You can get the average values on those planes and then make a costume defined function to subtract the values. Finally plot the result against time. cheers! |
May 30, 2016, 15:20 |
#3 | |
Bramantyo
Rep Power: 9 |
Is it P - P ? Thanks! |
2D Hypersonic Inlet in FLUENT - Convergence Issues | Fraisdegout | FLUENT | 6 | December 15, 2016 02:07 |
static vs. total pressure | auf dem feld | FLUENT | 17 | February 26, 2016 13:04 |
Pressure BC for combustion chamber | Giuki | FLUENT | 1 | July 19, 2011 11:35 |
pressure drop in the pipe | mike.mm | FLUENT | 6 | February 7, 2011 10:31 |
Monitoring Convergence in Fluent 5.0 | Tom Plikas | Main CFD Forum | 0 | April 6, 1999 17:10 |
