June 12, 2016, 07:25 |
Yplus adapt
Rafael Agujetas
Rep Power: 11 |
Hi everyone,
I´m simulating blood flow through an artery bifurcation in a 3D steady case. My turbulence model is k-w SST with a determined wall roughness. Once the simulation is cenverged the Yplus is between 10-60, and it would be beloww 1-2. I´m trying to use the fluent adapt function to fix the yplus below this value. I go to adapt function, I fix the Yplus min:0, max:1, and I click adapt. Then I compute the yplus value and it is below 1. But when I run the simulation again, after several iterations and the result is converged, I compute the Yplus, and it is between 10-60 again. Nonetheless results are very close to those obtained in the experimental phase. The only problem is the yplus. Can anybody suggest anything please?? |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 02:36 |
which yplus (SST) | sanchezz | CFX | 17 | January 11, 2010 04:45 |
Who stole my Yplus? | Chebeba | CFX | 4 | March 23, 2006 04:18 |
X-Y plot of Yplus in Fluent 5.3 | Luo | FLUENT | 24 | April 11, 2000 06:07 |
heat transfer coefficients with "bad" yplus | Andrew | Main CFD Forum | 4 | April 8, 1999 04:43 |
