Water solid jet simulated by DPM particles !!!!
Old   July 16, 2010, 04:22
Default Water solid jet simulated by DPM particles !!!!
bohis is on a distinguished road
Hi there!
I've been simulating water jet (diameter of 2 mm) impinging upon flat wall (100centigrades). Firstly, I did it via VOF model and results are OK especially heat fluxes agreed well with measured data.
Now I have switched the same case to DPM approach and I try to solve it with Lagrange particles (droplets). I know that I am breaking fluent limitation on an allowed volume fraction in a cell (10%), But I want to test it anyway.
I have already succesfully modeled a cold flow without heat transfer.
When I tried to simulate heat transfer with WallJet BC, I've got 70times lower values of HTC than I should have got.
Than I tried also switched to Wall Film BC with solving species transport, but here I've got negative values of HTC instead of possitive ones.
I've also written my own DPM-LAW for inert particles, but it has helped only a little.
Any suggestions ???
Thanks in advance!
Bohis
bohis is offline   Reply With Quote
Old   June 17, 2016, 08:32
Smile
James
Tensian is on a distinguished road
Originally Posted by bohis View Post
Hi there!
Any suggestions ???
Thanks in advance!
Bohis
Hi Bohis,
Have you solved your problem?
I cannot solve the heat transfer between a solid body (1000K) and water particles using DPM. It seems that particles are not cooling the body, it is only the air (continuous phase) that reduces temperature of the body.
I am considering heat transfer meshing the solid and using Couple BC at the interface.
Let me know your thoughts if you have successfully solved your problem.
Thanks in advance!
T
Tensian is offline   Reply With Quote
DPM - do the particles affect the liquid? Nikhil Dani FLUENT 0 January 1, 2009 11:58
Dispersed Solid particles in carrier gas (DPM) Frederik FLUENT 1 June 3, 2008 05:13
DPM - Melting of Solid particles Devin FLUENT 0 September 12, 2002 11:42
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 07:10
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
