Moving wall with absolute speed 0m/s vs stationary wall |
November 16, 2014, 22:28 |
Yushi Zhu
Rep Power: 11 |
I'm a little confused by the two sets especially in a frame motion. The premise is that I used tanslational frame motion to simulate flow passing a ball which is set as a wall with no slip on surface.The thing is: Case A: I set the ball with stationary wall.And velocity contour shows the ball does have velocity profile on its surface. Case B: I set the ball with moving wall whose absolute speed is 0m/s.And velocity contour shows all the velocity-magnitude on the ball surface is 0. In my opinion,I think case B is authentic since there's no slip on walls.But on the other side,I think "stationary" shoud equal to"moving wall with absolute speed at 0",what's the difference between case A and case B. Thank you so much. |
November 17, 2014, 23:46 |
Lucky
Rep Power: 65 |
There shouldn't be any difference. Fluent sets the wall velocityto 0 m/s when you specify stationary wall. What you are doing is the same as what Fluent is doing internally.
November 18, 2014, 04:01 |
Yushi Zhu
Rep Power: 11 |
Thanks ,Tran.I agree with u.I think the calculated data is the same,while the way it shows differs.
November 18, 2014, 10:56 |
Andrew Kokemoor
Rep Power: 13 |
If you are using a moving reference frame, stationary walls are always stationary relative to the cell zone. If you are specifying zero absolute velocity in Case B, you will get different results. If you specify zero relative velocity with a moving wall, you should get the same as Case A.
November 18, 2014, 11:26 |
Rick
Rep Power: 26 |
I agree with Andrew. It's not straightforward, but I remember I read it in ansys' guide.
If you want to specify a fixed wall, always use zero absolute velocity.
Google is your friend and the same for the search button! |
November 18, 2014, 20:48 |
#6 | |
Yushi Zhu
Rep Power: 11 |
July 9, 2016, 07:24 |
moving wall
alliche redha
Rep Power: 15 |
hi;
i want create a file profile for piston motion (.prof) What software should I use it. thanks; |
boundary |
Stationary wall in MRF | AGP | FLUENT | 2 | July 11, 2014 18:17 |
Apparent wind Speed (moving object) | Solo Sails | OpenFOAM Running, Solving & CFD | 11 | December 13, 2011 08:34 |
stationary wall vs. moving wall | user0314 | FLUENT | 0 | August 26, 2011 09:42 |
moving wall BC problem | Sourabh | Main CFD Forum | 1 | August 8, 2006 07:47 |
Values of k & epsilon in the moving wall | ghlee | Main CFD Forum | 1 | August 16, 1999 12:42 |
