June 28, 2016, 19:14 |
Selecting Heat Transfer Boundary Conditions
Tyler
Rep Power: 10 |
I am trying to model cooling fin heat transfer with convection. My problem definition includes having the heat sink have a power of 120 W, a heat transfer coefficient of 250 W/m^2-K, and a stream temp of 25 C. I am trying to model this in fluent. When trying to specify the wall boundary conditions, I can either specify the heat flux from the wall OR the heat transfer coefficient, free stream temp, and heat generation rate (W/m^3-K). I do not want to specify a heat generation rate, because at the base of my solid material, a volume of the heat sink is not specified. I would prefer to specify the heat transfer coefficient, the stream temperature and the power (or power per unit area), instead of trying to make up a heat sink volume. Is there a way to do this? |
June 29, 2016, 15:33 |
nm
Rep Power: 13 |
define some wall thickness say (1mm) and then specify heat generation rate.
July 10, 2016, 23:23 |
Tyler
Rep Power: 10 |
Creating a wall thickness does seem like a straightforward solution which I will try.
I was originally trying to create mixed boundary conditions, but Fluent would not allow me to specify what I wanted to. Thank you both for the advice! |
ansys, convection, fluent, heat transfer |
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 05:57 |
Boundary conditions for enabling heat transfer | dre028 | Main CFD Forum | 2 | March 30, 2014 00:09 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
natural convection | mehrdadeng | CFX | 10 | February 25, 2011 05:25 |
