Turbulence and wall function in multiphase flow
Like Tree1Likes
  • 1 Post By nvarma
Old   July 26, 2016, 07:21
Default Turbulence and wall function in multiphase flow
Daniel
Daniel_Khazaei will become famous soon enough
Hello guys
I'm simulating free surface flow around a ship with air and water!
I've search the forum to get information about choosing turbulence model and wall functions, and learned a lot...
However, in my case the flow around the ship consist of water and air and the y plus value ranges between 1.25 in the air region to 124 in the water region...
How can I keep the y plus above 30 as suggested by fluent guide?
Can I use Scalable wall function in this case?
I have tried to get y plus around 1 to use SST k-omega model, but the mesh quality decreased drastically...
best wishes
tnx in advance
Daniel_Khazaei is offline   Reply With Quote
Old   July 26, 2016, 16:50
nm
nvarma is on a distinguished road
By coarsening the mesh. This tool will help you determine how coarse: http://www.cfd-online.com/Tools/yplus.php
This is not clear. How can a turbulence model change your mesh?
nvarma is offline   Reply With Quote
Old   July 26, 2016, 18:15
Daniel
tnx for the answer mate
As I said the y plus variation is on the same wall (ship hull)! if I coarsen the mesh the minimum yplus increases but at the same time the maximum yplus surpass 300 limitation...
I may have been unclear here
I have refined the mesh to get yplus around 1 but so I can use SST k-omega model! however refining the boundary (inflation layer) decreases the mesh quality...
Old   July 27, 2016, 15:58
nm
that seems like a meshing related issue. May be you can create a near boundary mapped region manually instead of inflation layer so that you have more control.
Daniel_Khazaei likes this.
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
Turbulent wall treatment in multiphase flow regimes nero235 OpenFOAM Running, Solving & CFD 2 February 15, 2016 05:00
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 14:32
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
