Blade Rotation, Density Based Solve
Old   July 28, 2016, 10:38
Default Blade Rotation, Density Based Solve
gökmen
cfdkdk is on a distinguished road
I want to solve balde rotation problem. Its radius nearly 2 meter and its rotational velocity 6000RPM.
But I can not converge this problem with fluent. I use density based option, and decrease courant number but when Its rmp value exceed 500,600 The solution is diverged. The air properties is ideal gas because of high mach number.
Help!!!
cfdkdk is offline   Reply With Quote
Using Density based solver when calculate multiphase model maggie1533 FLUENT 0 February 26, 2014 01:13
Pressure based vs density based solver newbie384 FLUENT 2 July 5, 2013 02:04
Strange residuals of the Density Based Solver Pat84 FLUENT 0 October 22, 2012 15:59
Pressure gradient in UDF for density based solver matzb FLUENT 0 February 22, 2010 06:34
REAL GAS UDF brian FLUENT 6 September 11, 2006 08:23
