No heat transfer in transient simulation (Fluent) |
July 30, 2016, 09:46 |
LZ
Rep Power: 10 |
Hi, I am new to Fluent and I am running a transient simulation for a rotating disc rotor. I noticed that if I run a transient simulation by using the steady state result as the initial condition, the conduction on solid disc will occur and the temperature on my disc will keep changing with time. But, if I directly run the transient without steady state initial condition, the temperature will not change and no heat transfer can be observed. Can anyone help explain that? Thanks
transient conduction |
Heat Transfer Problem in FLUENT | eng_yasser_2020 | FLUENT | 3 | February 19, 2019 02:13 |
Exhaust Manifold Transient Heat Transfer Simulation | Jonny6001 | STAR-CCM+ | 9 | February 22, 2017 13:24 |
Quenching simulation : how to set up a conjugate heat transfer between solid&liquid | Rockda | FLUENT | 24 | August 30, 2016 06:33 |
Conjugate Heat Transfer transient | Sara28 | FLUENT | 0 | June 1, 2016 04:59 |
Fluent transient Simulation - varying Internal Heat generation : Help! | lamboram | FLUENT | 0 | September 14, 2015 04:37 |
