September 8, 2016, 00:22 |
Help with ship hull
Harold Aguirre
hello , i'm a student and need help with the simulation in fluent. Is like a ship hull but i have a problem with the simulation of two fluids the water and air, i don't know how to separate the boundary to simulate the multiphase.
Is something like in the image what i need. I'm just learning how to use ansys so any help you can give me will be really appreciate. I need some help. Thank you very much in advance. |
September 8, 2016, 02:32 |
Behrooz Jamshidi
Rep Power: 13 |
Hi
For meshing: 1-You should make one meshed volume with two faces on inlet,sides and outlet. 2-You should not seperate water and air volumes in meshing. 3-Use finer mesh near the water surface. For solver: 1-Initialize the solution with water volume fraction=1 in all places. 2-Patch the top half with water volume fraction =0 Now you have seperated water and air, then if the solver converge, it shows the waves around the hull on water surface. |
Ship hull with appendage as seperate patch runs into error | manoj_nav | OpenFOAM Running, Solving & CFD | 1 | March 13, 2016 09:12 |
How to output the water resistance on a Ship hull | Sachin m | OpenFOAM Post-Processing | 1 | January 26, 2015 12:24 |
Free surface comes above the hull of the ship | Sachin m | OpenFOAM Pre-Processing | 0 | September 4, 2014 00:08 |
Ship hull hydrodynamics | Costa | Main CFD Forum | 2 | May 19, 2012 21:41 |
Ship hull modeling on ANSYS CFX V11.0 | jorllam | CFX | 0 | August 1, 2007 12:43 |
