How many time-steps are included in each .dat file for Fluent transient simulations? |
March 30, 2015, 16:36 |
nm
Rep Power: 13 |
I just discovered the hard way that fluent .dat written using the autosave function after particular intervals (every 40 iterations here) store different number of time steps.
This is quite annoying. For instance results written at 480 iterations contain times 320, 360,400, 440 and 480. Results written, at 360 only have 360 and 320. Results written at 320 have, 320,280 and 240? Why are the .dat files so inconsistent? I noticed this only after I imported them to CFDpost. Thanks for reading. |
April 2, 2015, 08:45 |
nm
Rep Power: 13 |
I figured out a few other ways to track and write down the transient results but this still bothers me.
Anyone got any idea what determines the number of time steps in a fluent dat file written during calculation? |
April 3, 2015, 00:01 |
Lucky
Rep Power: 66 |
I did not think it was ever possible for Fluent to save data from old time-steps in a single .dat file since the .dat file should contain only data of the current state.
If you are running transient simulation with 1st order backward differencing, then naturally the .dat file will contain data at the current time-step plus the previous time-step. If you are running 2nd order, then the .dat file should contain the current time-step (n), the previous time-step (n-1), and the one before the previous time-step (n-2). It shouldn't contain n-40 time-steps. I don't know how that happens. |
April 3, 2015, 08:45 |
nm
Rep Power: 13 |
Right? I am confused as well. I was using Tecplot all my life but recently had to switch to CFDpost. So post-proc of transient simulations is a pain.
Anyway this is what I get when I import ONE timestep dat. Different timestep dat files have different number of timesteps stored and it's completely random. temp1.PNG |
September 20, 2016, 14:27 |
Attique Javaid
Rep Power: 11 |
did you find solution to this problem?
data file, fluent 14.5.7, transient analysis |
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error | FerdiFuchs | OpenFOAM Community Contributions | 27 | April 16, 2014 15:14 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 12:41 |
2.0.x on Mac OSX | niklas | OpenFOAM Installation | 74 | March 28, 2012 16:46 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
