September 23, 2016, 05:04 |
porous media model validation
James
Rep Power: 12 |
Dear all,
I have a question regarding porous media model in FLUENT. Well, to be fair, more than one question. I would like to compute pressure drop in a filter in 3D(in the complete geometry and across the filter) using porous media approach in FLUENT. So I need permeability in order to obtain viscous resistance (porosity epsilon is available). I have available the lineal velocity vs pressure drop curve (find attached the graph) for a type of coal. I would like to carry out simulations of a filter based on this material. So I have used the pressure drop and velocity of this curves, and also the dynamic viscosity to obtain permeability via Darcy's law: delta_P= (mu.U)/alpha where delta_P is pressure drop, mu is dynamic viscosity of the material (water in my case) , U is the velocity in the porous media and alpha is the permeability. So, here are my questions: 1, For the computations: For a T=25 ºC and lineal velocity of 12 m/h, pressure drop is about 3169 Pa/m, so if I have a porous media with length 0.998 m, then my delta_P=3169*0.998=3162.662 Pa. I obtain U dividing flow rate by cross sectional area of the filter. So, for the computation of permeability,should I use... alpha=(lineal_velocity*dynamic viscosity)/deltaP per meter or alpha=(velocity obtained from flow rate and cross sectional area*dynamics viscosity)/(deltaP_per meter*length of porous media) 2. The most important thing. If I do... surface integrals---Area weighted average---Pressure in the inlet plane of the porous media=Pin_porous surface integrals---Area weighted average---Pressure in the outlet plane of the porous media=Pout_porous delta_P_CFD=Pin_porous-Pout_porous Then, delta_P_CFD should be equal (or very similar) to deltaP_permeter*length of porous media???? I am not sure if I a m computing well permeability and I am worried about the way to use the curves attached to validate my FLUENT model. Really interested in your comments. I am sure the most of you have already used something similar... Thanks in advance, Tensian |
Porous Media Model reaction mechanism | umairjamil | FLUENT | 1 | July 2, 2016 08:23 |
LTNE model for partially filled porous media | Riki | FLUENT | 0 | June 25, 2015 04:24 |
local thermal non equilibrium model in porous media | adi.ptb | Fluent UDF and Scheme Programming | 0 | November 1, 2014 15:00 |
How to model granular flow through porous media | Axius | FLUENT | 2 | August 7, 2014 10:34 |
CFX Model for dispersion of gas through a porous media filled with Oil | deepmetal | CFX | 13 | November 27, 2010 20:34 |
