Fluid Flow between the 2 Cylinders
Old   October 4, 2016, 01:08
Default Fluid Flow between the 2 Cylinders
Sadia
khattaksadia is on a distinguished road
Hello Everyone,
I'm at beginner level in CFD (CFX, Fluent). I wish to do the Fluid Structure Interaction taking under consideration as follows:-
2 concentric hollow cylinders. The fluid flowing through the inner cylinder is Air & the Fluid Flowing between the Outer & Inner Cylinder is Water (i. e., water is flowing outside the inner cylinder but inside the outer cylinder).
I'm unable to figure out how to do it. Kindly help me out.
Thanks.
khattaksadia is offline   Reply With Quote
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Want Impeller Driven Fluid Flow: What Inlet and Outlet BC to use for Centrifugal Pump Zev Xavier FLUENT 3 May 9, 2016 06:42
transient, impregnating flow problem fgommer FLUENT 0 February 29, 2012 16:10
Newbie: advantages/disadvantages of "penalty formulation" incompressible fluid flow bzz77 Main CFD Forum 2 November 1, 2011 03:32
