Heat Exchange
Old   October 10, 2016, 23:47
Default Heat Exchange
Abayomi T. LAYENI
yomilayeni is on a distinguished road
Send a message via Skype™ to yomilayeni
I need to set up a solar heat exchange. I have a heat box with glass cover. A pipe runs through the box to be heated by solar energy. Water is to be pumped through the pipe to extract the heat. How do I set this up in Ansys Fluent?
yomilayeni is offline   Reply With Quote
Old   October 12, 2016, 05:25
mome is on a distinguished road
i find this question is too general... you should approach it yourself like any modelling problem and ask yourself what the physical mechanisms are that you want to explain. what detail can you neglect and what is essential. break it down and start with the core of the problem and go step by step into complexity. good luck
mome is offline   Reply With Quote
Old   October 13, 2016, 06:23
Abayomi T. LAYENI
I want to simulate the effect of the fluid flow rate on the amount of heat absorbed from the heat box. Also, I want to simulate the effect of using different fluids for the systems. These simulations at heat flux of 200 -1,000 W/m2. The heat box is to reduce the heat flow to a chamber below the heat box.
Energy residual and total heat exchange fluctuation nirmal_singh STAR-CCM+ 0 August 17, 2016 04:41
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
Problem of heat balance in Coal Boiler simulation DG FLUENT 9 December 25, 2008 20:57
Multi phase heat exchange simulation. JP CFX 1 May 26, 2008 05:22
heat exchange Silvia FLUENT 0 August 19, 2005 10:34
