September 19, 2003, 05:53 |
LES Tutorial using fluent
Is there any LES tutorial using FLUENT ?
Thanks Anindya |
September 25, 2003, 05:05 |
Re: LES Tutorial using fluent
There is. Fluent has an acoustic model where LES is used with flow over a cylinder.
Why do you need a tutorial using Fluent? LES requires a fine mesh and small time step. Other than that, just select the LES and run it. What are you trying to accomplish? How can I help you? |
September 25, 2003, 11:36 |
I am trying to simulate an impinging jet flow using LES. I would like to see the jet coming out of the nozzle and then hitting the ground plane. I would also like to see how the wall jet then develop and the boundary layer profile at various r/D distances on the ground surface.
I am also trying to see how the ground pressures change if instead of having a stationary jet, the jet nozzle is moving at some velocity v relative to the ground plane. How can I do that? Can you give me some insight to modeling these? |
October 14, 2016, 04:03 |
raunak jung pandey
Rep Power: 9 |
Are inlet conditions different for LES ?
October 14, 2016, 10:38 |
Lucky
Rep Power: 66 |
You need time-accurate inlet boundary conditions for LES. That is, you "cannot" just specify the time-averaged mean flow quantities, you need to specify the instantaneous quantities. You can use like the synthetic vortices like the spectral synthesizer if needed to generate the instantaneous quantities from time-averaged quantities. But philosophically, the need for time-accurate inlet conditions is what makes LES harder than RANS. |
October 16, 2016, 01:17 |
raunak jung pandey
Rep Power: 9 |
I see use of TUI COMMAND /solve/initialize/init-instantaneous-vel
to superimpose the synthesized turbulence on the mean flow. Is this practice appropriate to generate instantaneous velocity ? |
October 16, 2016, 03:16 |
Lucky
Rep Power: 66 |
That tool is for generating initial conditions for LES from RANS or mean-flow data. It is for perturbing the mean flow to give it some synthetic turbulence or else the LES will stay laminar. Its usable for generating instantaneous velocity for the initial conditions but you still need boundary conditions!
October 17, 2016, 09:17 |
Rep Power: 10 |
It is pretty much as LuckyTran said. If you have a system that does not contain any inlets and you have a converged RANS solution of the system available, you can switch to LES and let the flow field develop over time till it reaches a pseudo-steady state. The utility /solve/initialize/init-instantaneous-vel is useful in the sense that it introduces a perturbation to the RANS solution and so you should achieve the pseudo-steady state earlier. However, if an inlet is present in the system, you surely need a way how to perturb the inlet condition. Fluent gives you two options, I think - spectral syntesizer and vortex method.
IC engine simulation tutorial by FLUENT | yash | FLUENT | 4 | April 6, 2015 19:44 |
LES and near wall treatment approach in Fluent | khosro1355 | Main CFD Forum | 1 | July 10, 2009 10:49 |
IC engine simulation tutorial by FLUENT | yash | Main CFD Forum | 1 | April 21, 2009 05:05 |
Request for pipe bifurcation fluent tutorial case | Giorgos Momferratos | FLUENT | 0 | October 20, 2008 15:10 |
FDS vs Fluent, what's the difference on LES? | Jim | FLUENT | 0 | August 12, 2006 15:32 |
