How to check convergence in UDF for dynamic mesh |
Prikane
Rep Power: 10 ![]() |
Dear colleagues,
I am working with dynamic mesh (spring-based smoothing method), and I need to move one surface, on which UDF for dynamic mesh is hooked, every time step when convergence is achieved, because it is very important that pressure field is well calculated. If convergence is not achieved in previous time step, the mesh will not move in the current time step and every other following. So I was wondering is there any way I could check convergence from my UDF for dynamic mesh? Thanks in advance, Prikae |
convergence check, dynamic mesh |
Convergence | Centurion2011 | FLUENT | 48 | June 14, 2022 23:29 |
Mesh check failed | aja1345 | FLUENT | 3 | August 17, 2016 21:27 |
UDF: Have 3 dynamic mesh regions working well in 2D, but not in 3D | gabriel09 | Fluent UDF and Scheme Programming | 1 | May 12, 2016 06:06 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
Naca 0012 (compressible and inviscid) flow convergence problem | bipulsaha | FLUENT | 1 | July 6, 2011 07:51 |
