August 13, 2009, 07:56 |
problem with reading case file
Shengyi Wang
Rep Power: 17 |
Hi All,
I encountered a very weird problem when I am trying to read a case and data file. It says: Error: prf-set-var: invalid flonum Error Object: nan It is just a very simple steady case without UDF. I do not know what happens. Can anyone give some help? Thanks a lot. Best wishes, Shengyi |
August 13, 2009, 18:25 |
Sean Delfel
Rep Power: 16 |
Hi Shengyi,
I don't know what that error refers to, but maybe can help you narrow down the problem. Does the error occur when reading the case file or the data file? If it's the case file, have you tried re-importing the mesh to Fluent to see if there's any issues or warnings then? If it's the data file, was the data created using the same case file? Also, can you re-initialize data on the mesh without receiving the same error? Cheers, -sean |
August 14, 2009, 02:39 |
#3 | |
Shengyi Wang
Rep Power: 17 |
Thanks a lot for reply. The error happens when reading the case file. The problem is that I employ periodic boundary conditons. So every time I re-importing the mesh, I need to modify the zones and create the periodic bc. Thus, the new case may not match the data file. So I cannot read the data file if I import the mesh. Anyway, thanks a lot. Good luck, Shengyi |
February 2, 2013, 01:25 |
%prf-set-var: invalid flonum
sundaravadivel
Dears
i am using fluent 6.3 for my work (wind turbine analysis with single reference frame). if i want to open a case and data file which was done with the same version.. i am getting the below mentioned error. Error: %prf-set-var: invalid flonum Error Object: () please help me to overcome this. |
November 22, 2016, 01:32 |
sanju
Rep Power: 9 |
Hello sir,
I have one problem, kindly first go through it. I have problem with with cell zone BC. I just considered the cylinder and given inlet velocity at one side and outlet pressure at the other side. 1. defined the surfaces as the temperature body 2. inlet air velocity 8 m/s. 3. trying to find the cooling response of the system. In cell zone BC when I define cylinder as fluid then there was no error, but when I defined it as solid the error was showing as below Error - %prf-set-var: invalid flonum Error object - 1.£ inf Kindly anyone suggest what is the problem. Thanks in advance. |
November 23, 2016, 12:19 |
#6 | |
Kushal Puri
Rep Power: 12 |
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise | mbeaudoin | OpenFOAM Installation | 20 | June 17, 2008 06:43 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
another problem about saving a case: Urgent | J.Z | Phoenics | 0 | January 15, 2007 15:02 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
