Fluent convergence problem
Old   November 24, 2016, 10:17
Default Fluent convergence problem
engeagle
engeagle is on a distinguished road
I'm new with Fluent. I study on a simple analysis. The flow is laminar. Firstly, I generated the mesh. I consider that mesh quality is enough. The highest skewness value is 0.77. And the mesh number is 1300000. I solve continuity, momentum and energy equations. The residual values converge to a certain value. For example, the scaled residual value for continuity equation converges to 2e-03, for energy equation converges to 1e-06, for momentum equations converges to 4e-05. But after these values, the scaled residual values diverge and the solution does not converge. Is this condition acceptable? How can I solve this problem?
engeagle is offline   Reply With Quote
Old   November 25, 2016, 14:58
shereez234's Avatar
M Sereez
shereez234 is on a distinguished road
If the solution diverges then it is not acceptable right?
Perhaps you should use under relaxation factors to stabilize the solution and also when asking for help If i were you I would give more information like Inlet, Outlet, Phase, Numerical setup.
Regards
Shereez
shereez234 is offline   Reply With Quote
Old   November 26, 2016, 13:45
engeagle
Regards
Shereez
Thank you for your answer.
I make this simulation to validate my model, so I use only air as fluid. I use the quarter model. There are two symmetry faces. Three velocity inlets and two outlets. I defined the outlets as pressure outlets. I use first order upwind for the initial solution.
I use the default values for under relaxation factors. Should I change them?
Old   November 26, 2016, 14:53
Onur Özcan
oozcan is on a distinguished road
residual behaviours is decisive to change under relaxation factor. URF's being decreased (all regarding variable <1 ) show convergence/divergence behaviours of scaled residuals in a short time.
oozcan is offline   Reply With Quote
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
Problem in compiling fluent UDF lunched from MATLAB cfdman10 Fluent UDF and Scheme Programming 16 December 5, 2019 05:32
Fluent - license problem. Marcin FLUENT 3 April 13, 2018 16:33
convergence problem in ansys fluent israr.iitp Visualization & Post-Processing 0 September 5, 2015 06:01
Problem in using parallel process in fluent 14 Tleja FLUENT 3 September 13, 2013 10:54
