November 24, 2016, 10:17 |
Fluent convergence problem
engeagle
Rep Power: 10 |
I'm new with Fluent. I study on a simple analysis. The flow is laminar. Firstly, I generated the mesh. I consider that mesh quality is enough. The highest skewness value is 0.77. And the mesh number is 1300000. I solve continuity, momentum and energy equations. The residual values converge to a certain value. For example, the scaled residual value for continuity equation converges to 2e-03, for energy equation converges to 1e-06, for momentum equations converges to 4e-05. But after these values, the scaled residual values diverge and the solution does not converge. Is this condition acceptable? How can I solve this problem? |
November 25, 2016, 14:58 |
If the solution diverges then it is not acceptable right?
Perhaps you should use under relaxation factors to stabilize the solution and also when asking for help If i were you I would give more information like Inlet, Outlet, Phase, Numerical setup. Regards Shereez |
November 26, 2016, 13:45 |
#3 | |
engeagle
Rep Power: 10 |
I make this simulation to validate my model, so I use only air as fluid. I use the quarter model. There are two symmetry faces. Three velocity inlets and two outlets. I defined the outlets as pressure outlets. I use first order upwind for the initial solution. I use the default values for under relaxation factors. Should I change them? |
November 26, 2016, 14:53 |
#4 | |
Onur Özcan
Rep Power: 12 |
Convergence | Centurion2011 | FLUENT | 48 | June 14, 2022 23:29 |
Problem in compiling fluent UDF lunched from MATLAB | cfdman10 | Fluent UDF and Scheme Programming | 16 | December 5, 2019 05:32 |
Fluent - license problem. | Marcin | FLUENT | 3 | April 13, 2018 16:33 |
convergence problem in ansys fluent | israr.iitp | Visualization & Post-Processing | 0 | September 5, 2015 06:01 |
Problem in using parallel process in fluent 14 | Tleja | FLUENT | 3 | September 13, 2013 10:54 |
