Periodic boundary condition error
Old   May 11, 2020, 03:26
Unhappy Periodic boundary condition error
baeblue is on a distinguished road
I want to make a simulation of axial fan and use Periodic Boundary Condition. But i still cant to make my side wall, to be a periodic. i've been used the non-conformal. but it still cant work. Please, i need help.
While in TUI show like this
/grid/modify-zones> make-periodic Periodic zone [()] 5 Shadow zone [()] 7 Rotational periodic? (if no, translational) [yes] yes
Create periodic zones? [yes] yes
Error: Failed to make zones periodic. Error Object: #f
baeblue is offline   Reply With Quote
Old   May 11, 2020, 03:47
Default Periodic BC
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Creation of periodic boundary requires conformal mesh across both periodic boundaries. For a axial fan, periodic boundary is not a good condition.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   May 11, 2020, 06:22
How about using non-conformal? honestly i've try it too for the conformal. but it still cant work.
so do you have any methode suggestion for me, to simulate axial fan?
Old   May 11, 2020, 06:34
Behrooz Jamshidi
CFD-fellow is on a distinguished road
Besides conformal mesh on periodic boundaries, go to cell zone conditions>edit and see if the rotation axis is the same as your fan rotation axis.
CFD-fellow is offline   Reply With Quote
Old   May 11, 2020, 07:27
thank before, but i just did it. and it's still cant work. i've already change the rotation axial into 0 0 1. unfortunelly still cant work
Old   May 11, 2020, 11:17
Default Periodic Conditions
vinerm's Avatar
Vinerm
If the mesh is same at both boundaries that are supposed to be periodic, then you can use TUI to generate periodic boundary. If that is not the case, then change both of the boundaries to Interface using Boundary Conditions panel. Then, go to Mesh Interface, and create Periodic Boundary using Interface option. This is less accurate and more time-consuming per iteration but the difference won't be significant if meshes on both boundaries have similar scale.
In any case, you need to set up the cell zone origin and its axis correctly before creating periodic boundary.
Regards,
Vinerm
Old   May 12, 2020, 13:00
thanks, but i did it before and still cant work. in case you said to make it by TUI need same mesh. is it relate to make that using Model Mesh and Symetric Geomtry?
Old   May 12, 2020, 13:30
Default Periodic BC
vinerm's Avatar
Vinerm
If you use Interface option to generate periodic bc and it still is unable to generate it, then most likely the error is in your cell zone setup (origin and axis) or name selections of the periodic boundaries.
Regards,
Vinerm
Old   May 14, 2020, 12:29
i still get confuse. cause the warning said about the number cell zone isn't same
Old   May 14, 2020, 15:00
Default Warning
vinerm's Avatar
Vinerm
Instead of rephrasing, better to copy the Warning issued by Fluent in the post. That will be more helpful in understanding the issue.
Regards,
Vinerm
Old   May 15, 2020, 13:54
Warning : Number of elements does not match between zone 5 and 7
Old   May 15, 2020, 14:32
Default Different number of faces
  #12
vinerm's Avatar
Vinerm
Since there are different number faces on each boundary, you cannot use TUI commands to generate periodic boundary. The alternative is to use Mesh Interface with Periodic Boundary Condition option. Convert both boundaries to Interface under Boundary Conditions. Then, under Mesh Interfaces, create an interface using both boundaries. Do it manually instead of Automatic Generation and select Periodic BC option. There are two periodic option, one is boundary condition and the other one is for periodic repeats. Select periodic boundary condition.
Regards,
Vinerm
Old   May 15, 2020, 16:32
thanks cause its work. thank u so much
Old   May 15, 2020, 16:45
I have another case. maybe you can help me to solve this problem.
Dot product of flow direction and area normal is zero.
Check the specified flow direction on Mass Flow Inlet boundary
conditions for thread 9.
do you know why this sign show up?
Old   May 15, 2020, 16:47
Default Mass Flow Inlet
  #15
vinerm's Avatar
Vinerm
Check the boundary with zone ID 9 where you have mass flow inlet. You might have chosen direction instead of normal to boundary. Either make it normal to boundary or provide correct direction. If you have many inlet boundaries, then following command could be useful to find out the name of the boundary
(zone-id->name 9)
Regards,
Vinerm
airfoil 3d, axial fan design, fluent 14 to fluent 15., periodic boundary fluent
[swak4Foam] swak4foam openfoam 7 installation problem Andrea23 OpenFOAM Community Contributions 1 February 17, 2020 18:11
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 04:53
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
