Heat Transfer Coefficient not changing with fluid temperature/ Wall temperature |
November 29, 2016, 23:24 |
cfd_msc
Hello All,
I was trying to change fluid temperature and wall temperature and find out Heat transfer coefficient. But I'm getting a constant HTC. note : Im using nanofluid properties |
November 30, 2016, 08:45 |
Lucky
Rep Power: 66 |
Sounds correct! Heat transfer coefficient is a property of the flow and it shouldn't change with temperature, except in reality there are non-linearities.
November 30, 2016, 12:08 |
Onur Özcan
Rep Power: 12 |
heat transfer coefficient is actually convective heat transfer coefficient (w/m2K) and it is not flluid property. As Lucky train said, it only changes with flow model you have specifed
December 1, 2016, 05:02 |
#4 | |
Kushal Puri
Rep Power: 12 |
If the fluid flow rate is same and temperature is increasing or decreasing then htc has to be change. As there will be change in temperature difference. |
December 1, 2016, 09:02 |
Lucky
Rep Power: 66 |
The Nusselt number is a similarity variable and depends only on Reynolds number and Prandtl number.
Nu = fn(Re,Pr) From Nu=h*L_ref/k_ref Heat transfer coefficient is thereby h = Nu*k/L There's no temperature! Newton's law of cooling defines heat transfer coefficient as: q" = h*(T-Tref) Which means that if the temperature changes, the q" changes but not the heat transfer coefficient The only reason heat transfer coefficient should change, is due to non-linearities. i.e. Reynolds number, Prandtl number, k_ref, L_ref are temperature dependent quantities. If the heat transfer coefficient did change, it would have to be for one of those reasons. However, if you tell me that you changed the wall temperature and heat transfer coefficient did not change, then I will automatically respond with it's not supposed to. |
fluid temperature, heat tranfer coefficient, htc, wall temperature |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Compression stoke is giving higher pressure than calculated | nickjuana | CFX | 62 | May 19, 2015 13:32 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 17:30 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
