Is it possible to write functions of physical properties
Old   December 2, 2016, 05:20
Default Is it possible to write functions of physical properties
Onur Özcan
oozcan is on a distinguished road
I would like to find out how to write some function in materil.
Could anyone help me with out this issue?
Kind Regards,
oozcan is offline   Reply With Quote
Old   December 4, 2016, 08:42
Quang Le Dang
SPH_CFD is on a distinguished road
Kind Regards,
in material tables, have a solution to choose userdefine. You can use it to define your properties
SPH_CFD is offline   Reply With Quote
Old   December 6, 2016, 02:33
Onur Özcan
userdefine>browser> ....
txt. file should be available ? or what kind of thing should it be chosen?
Please bring up the subject,
Kind Regards,
Old   December 6, 2016, 07:40
Quang Le Dang
Kind Regards,
You will use UDF and can take a look here. It is similar to your problem
https://www.sharcnet.ca/Software/Flu...df/node233.htm
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 21:43
[Helyx OS] Helyx-OS (GUI for SnappyHexMesh elvis OpenFOAM Community Contributions 210 January 30, 2017 18:57
Partition does not start on physical sector boundary!!?? immortality Lounge 1 December 8, 2013 15:04
Air physical properties at high temperatures zombiaska Main CFD Forum 2 March 12, 2012 17:59
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
