Checking UDF material properties
Old   December 2, 2016, 05:57
Default Checking UDF material properties
Simon
salumi is on a distinguished road
Hey,
Since for my simulation I am using water from sub-to supercritical state
i had to use a UDF (which i kindly was provided with from another Fluent User) to input a table of discrete material properties.
I can compile and then load the library, but i am not sure how i can check if the values are working correctly?
I tried the reference values tab, and compute values from inlet (for which i changed the temperatures) but the other properties don't seem to change.
Is this the correct way to check fluid properties?
Is there another way, to maybe plot e.g. density over temperature?
Thanks!
salumi is offline   Reply With Quote
Fluent UDF to interpolate material properties from Temp and Pressure dependent table lablan Fluent UDF and Scheme Programming 14 June 21, 2021 22:56
checking for C++ compiler default output file name... configure: error: C++ compiler dhxlxz SU2 Installation 2 September 7, 2013 11:08
[GAMBIT] Problem with interior faces miro2000 ANSYS Meshing & Geometry 11 August 24, 2013 14:00
Material Properties for Sat. Liquid and Sat. Vapor Blackhawks84 FLUENT 0 September 17, 2012 19:11
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
