How to use UDF or other ways to get the velocity value in grid center in 3D? |
August 26, 2018, 02:51 |
Huo
Rep Power: 8 |
Dear all,
I want to get the velocity value in every grid center in a surface in a 3D model. The position of grid center point is known, but there are lots of points need to be read . So which Define macro in UDF can we use to get the velocity data? or some other ways? Thanks for your attention. I will appreciate it if you can help me. Waiting for you. |
fluent, udf |
3D UDF Paraboilc Velocity Profile (Can't Maintain) | Sing | FLUENT | 12 | August 7, 2017 06:25 |
how to put udf inlet velocity and udf outlet pressure in fluent | raminostadi | Fluent UDF and Scheme Programming | 4 | July 3, 2017 06:43 |
Having trouble adapting serial UDF to work in parallel | muyuntao | Fluent UDF and Scheme Programming | 1 | November 10, 2015 13:42 |
How to approach calculating a stream function given a velocity profile on a grid | ComFlu | Main CFD Forum | 1 | October 25, 2009 13:25 |
Variables Definition in CFX Solver 5.6 | R P | CFX | 2 | October 26, 2004 02:13 |
