Y+ problem
Old   December 8, 2016, 05:39
Default Y+ problem
Other
DuFFman_EsP is on a distinguished road
I'm making an aerodynamic study in 2D Fluent on the profile of a truck (basically a couple of rectangles). I have meshed the geometry in Gambit and used the boundary layer utility to create the boundary layer from the value of y + I had previously calculated. (Characteristic length, length of the cab, speed 22.22 m / s). I have created the boundary layer with the first row obtained, 1.2 growth factor and so on. I have meshed the whole domain and then I move to Fluent.
The drag coefficient obtained seems to be valid, but no matter the different meshes or methods of calculation I used, I can not get a value of y + under 400 on the wall of the truck .....
Thank you in advance.
DuFFman_EsP is offline   Reply With Quote
Old   December 8, 2016, 07:01
Quang Le Dang
SPH_CFD is on a distinguished road
I think you can come back Gambit and decrease initial height of Boundary Layers. Y+ depends on distance from wall to first layer
Sent from my LG-F260S using CFD Online Forum mobile app
SPH_CFD is offline   Reply With Quote
Old   December 8, 2016, 07:20
Onur Özcan
oozcan is on a distinguished road
if you would like to see under a value under 400 for y+
please check regarding link and fomulas including y+
y+=y*ut/m ut=friction velocity m=viscosity. y= first layer thickness
Solution is that you should decrease first layer tickness, increasing layers (avoiding higher aspect ratio)
https://en.wikipedia.org/wiki/Law_of_the_wall
oozcan is offline   Reply With Quote
Old   December 8, 2016, 07:25
Other
Thank you,
I will try again!
Old   December 8, 2016, 08:56
Other
I tried once and y+ han not changed a lot. It is still more than 400.
Old   December 8, 2016, 09:00
Onur Özcan
what did you give y+ for meshing?
Old   December 8, 2016, 10:54
Other
I think that I have found the problem. I have y+=0,001. But I also have another wall (the floor) and probably its boundary layer could be giving me some problems.
I´m trying to create two boundary layers for both, truck and floor.
Old   December 8, 2016, 20:19
Other
I´ve done it! and it works. Now, I have an y+=70 after calculating.
Thank you!
Old   December 8, 2016, 23:54
Onur Özcan
Thank you!
I am pretty good to be resolved it and How?
I was trying to post last night about boundary layer you were going to do. Life is busy!, well, probably, I think that you made boundary layer thickness give on interfaces of floor and truck in enclosure domain
Old   December 9, 2016, 04:18
Other
I had forgotten to made a boundary layer for the floor (wall) and now I have y+=65-71 for different meshes.
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
