December 8, 2016, 05:39 |
Y+ problem
Other
Rep Power: 9 |
I'm making an aerodynamic study in 2D Fluent on the profile of a truck (basically a couple of rectangles). I have meshed the geometry in Gambit and used the boundary layer utility to create the boundary layer from the value of y + I had previously calculated. (Characteristic length, length of the cab, speed 22.22 m / s). I have created the boundary layer with the first row obtained, 1.2 growth factor and so on. I have meshed the whole domain and then I move to Fluent. The drag coefficient obtained seems to be valid, but no matter the different meshes or methods of calculation I used, I can not get a value of y + under 400 on the wall of the truck ..... Thank you in advance. |
December 8, 2016, 07:01 |
Quang Le Dang
I think you can come back Gambit and decrease initial height of Boundary Layers. Y+ depends on distance from wall to first layer
Sent from my LG-F260S using CFD Online Forum mobile app |
December 8, 2016, 07:20 |
#3 | |
Onur Özcan
Rep Power: 12 |
please check regarding link and fomulas including y+ y+=y*ut/m ut=friction velocity m=viscosity. y= first layer thickness Solution is that you should decrease first layer tickness, increasing layers (avoiding higher aspect ratio) https://en.wikipedia.org/wiki/Law_of_the_wall |
December 8, 2016, 07:25 |
Other
Rep Power: 9 |
Thank you,
I will try again! |
December 8, 2016, 08:56 |
Other
Rep Power: 9 |
I tried once and y+ han not changed a lot. It is still more than 400.
December 8, 2016, 09:00 |
Onur Özcan
Rep Power: 12 |
what did you give y+ for meshing?
December 8, 2016, 10:54 |
Other
Rep Power: 9 |
I think that I have found the problem. I have y+=0,001. But I also have another wall (the floor) and probably its boundary layer could be giving me some problems.
I´m trying to create two boundary layers for both, truck and floor. |
December 8, 2016, 20:19 |
Other
Rep Power: 9 |
I´ve done it! and it works. Now, I have an y+=70 after calculating.
Thank you! |
December 8, 2016, 23:54 |
#9 | |
Onur Özcan
Rep Power: 12 |
I was trying to post last night about boundary layer you were going to do. Life is busy!, well, probably, I think that you made boundary layer thickness give on interfaces of floor and truck in enclosure domain |
December 9, 2016, 04:18 |
Other
Rep Power: 9 |
I had forgotten to made a boundary layer for the floor (wall) and now I have y+=65-71 for different meshes.
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
