Boussinesq approximation (temperature gradient range) |
December 12, 2016, 09:46 |
a0407
Rep Power: 9 |
I'm simulating a natural convection in fluent using bossinesq approximation. I was told that the temperature gradient of the system cannot be large. So, what is the range of the tempareture gradient that acceptable to use in fluent?
In experimental works, Rayleigh number of the natural convection is varies by the change of the temperature gradient. In CFD, what variable can we change to increased the Rayleigh number as the temperature gradient cannot be increase too much? |
December 13, 2016, 02:32 |
Lucky
Rep Power: 66 |
These are not CFD limitations. There are no limitations in Fluent, you impose the Boussinesq approximation and that's it.
The boussinesq approximation poses that the density change is linearly proportional to the temperature change. Boussinesq is valid as long as this is true physically. If temperature variations are large then the Boussinesq approximation is no a longer valid physical approximation. Again, this is fault of the numerics but a modeling error and user fault. Use an explicit equation of state like the ideal gas law if you don't want to deal with the temperature range issue. |
December 13, 2016, 03:18 |
a0407
Rep Power: 9 |
Thank you for your answer.
December 11, 2023, 12:05 |
#4 | |
Kadi
Rep Power: 12 |
boussinesq approximation, fluent, natural convection |
question regarding LES of pipe flow - pimpleFoam | Dan1788 | OpenFOAM Running, Solving & CFD | 37 | December 26, 2017 14:42 |
Periodic flow using Cyclic - comparison with Fluent | nusivares | OpenFOAM Running, Solving & CFD | 30 | December 12, 2017 05:35 |
How to create a temperature gradient in thin wall and two dimensions | leggman7 | Main CFD Forum | 0 | October 29, 2013 23:21 |
temperature gradient for use in surface monitor | Catherine | FLUENT | 1 | August 24, 2012 09:10 |
Boussinesq approximation, help please! | engahmed | FLUENT | 0 | May 20, 2010 11:25 |
