Crank angle for peak swirl ratio value is not matching.. |
January 18, 2017, 01:44 |
kazuki
Rep Power: 9 |
Hi, I'm simulating the intake stroke of a Diesel Engine in Fluent. When I got results for Swirl ratio-Crank angle curve, the peak swirl ratio value is matching with my experimental value but, the crank angle at which the peak occur is not matching. I'm not getting, why the value of crank angle for peak value pressure are not matching.
How to solve this problem?? |
Problem with divergence | TDK | FLUENT | 13 | December 14, 2018 06:00 |
Crank angle for peak pressure value is not matching.. | Pawan30 | FLUENT | 1 | November 23, 2016 01:56 |
Quantifying the swirl in CFX, Swirl Number/Swirl Angle | tauqirnawaz | CFX | 23 | July 24, 2016 22:28 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
pressure eq. "converges" after few time steps | maddalena | OpenFOAM Running, Solving & CFD | 69 | July 21, 2011 07:42 |
