discontinuities between domains
Old   February 1, 2017, 06:54
Default discontinuities between domains
Ronald Thompson
dynamic is on a distinguished road
I'm trying to run a simple model of the a 2D VAWT.
I have setup a mesh interface between my rotating and static domains, with a periodic boundary condition of rotation type. and this automatically creates additional boundary conditions of "rotation-side1-wall-rotating_edge" & "rotation-side2-wall-static_edge"
however after I run my model, there is discontinuities in the flow field between the two domains (see attached image). my rotating domain is 2x times the diameter of the rotor.
I have edge sizing on both edges of the domains so they match up.
is it these additional wall boundary conditions that are automatically created that is causing my discontinuities?
any advice would be created appreciated.
Thanks
dynamic is offline   Reply With Quote
flow, fluent 17.1, interface discontinuity, sliding mesh, vertical wind turbine
Interpolate solution onto only some target domains gotang CFX 3 March 6, 2017 07:12
[ANSYS Meshing] Displaying solid domains in CFD Post without meshing them. hda ANSYS Meshing & Geometry 5 October 24, 2016 09:26
Does not assemble the domains to make a block although it is a close volume mollaee.saeed Pointwise & Gridgen 5 October 8, 2015 03:46
Porous domains in contact 0906536m CFX 3 September 30, 2013 18:34
Multiple Solid Domains - Interfaces Scott CFX 8 July 31, 2008 15:20
