DPM Injection from file
Old   February 2, 2017, 11:18
Unhappy DPM Injection from file
TimTUBAF is on a distinguished road
Hi everyone,
I'm currently trying to load a .txt-file into Fluent to get my injection and my simulation running.
If I try to list my file, there isn't any output, except:
Particle streams from injection-0:
STREAM ...........................INITIAL VALUES...........................
NO TYP (X) (Y) (Z) (U) (V) (W) (T) (DIAM) (MFLOW)
4 particles not found in injection injection-0
I've have attached my .txt-file.
I have read that the first line with the (x y z u v w etc) should be removed, doesn't work either.
Should the .txt-file be coded in ASCII or somethin else?
Could any of you guys please help me out?
Thanks
Tim
File Type: txt injection.txt (248 Bytes, 86 views)
TimTUBAF is offline   Reply With Quote
Old   February 3, 2017, 11:47
AHF
AHF's Avatar
amirhossein
AHF is on a distinguished road
Originally Posted by TimTUBAF View Post
Hi everyone,
Thanks
Tim
Hi
change the file format from *.txt to *.inj
good luck
amirhosseinfardi94@gmail.com
AHF is offline   Reply With Quote
Old   February 4, 2017, 12:50
Originally Posted by AHF View Post
Hi
good luck
I changed the file format to *inj as you said, tried to load it into fluent... same problem again...
Old   February 4, 2017, 14:21
AHF
AHF's Avatar
amirhossein
try this file that attached.
remember to change type to inj format
File Type: txt edited.txt (248 Bytes, 148 views)
Old   March 6, 2018, 12:00
Default Dpm injection file
nirjhor
sonnet is on a distinguished road
can anyone helpme out here.what is wron with this file. it is not working
(( x y z u v w diameter temperature mass-flow ) name )
(( 30 0 -140.98 0 0 31.678 0.25 288 0.5 ) 1 )
(( 28.97777479 7.764571353 -140.98 0 0 31.678 0.25 288 0.5 ) 2 )
(( 25.98076211 15 -140.98 0 0 31.678 0.25 288 0.5 ) 3 )
(( 21.21320344 21.21320344 -140.98 0 0 31.678 0.25 288 0.5 ) 4 )
(( 15 25.98076211 -140.98 0 0 31.678 0.25 288 0.5 ) 5 )
(( 7.764571353 28.97777479 -140.98 0 0 31.678 0.25 288 0.5 ) 6 )
(( 1.83772E-15 30 -140.98 0 0 31.678 0.25 288 0.5 ) 7 )
(( -7.764571353 28.97777479 -140.98 0 0 31.678 0.25 288 0.5 ) 8 )
(( -15 25.98076211 -140.98 0 0 31.678 0.25 288 0.5 ) 9 )
(( -21.21320344 21.21320344 -140.98 0 0 31.678 0.25 288 0.5 ) 10 )
(( -25.98076211 15 -140.98 0 0 31.678 0.25 288 0.5 ) 11 )
(( -28.97777479 7.764571353 -140.98 0 0 31.678 0.25 288 0.5 ) 12 )
(( -30 3.67545E-15 -140.98 0 0 31.678 0.25 288 0.5 ) 13 )
(( -28.97777479 -7.764571353 -140.98 0 0 31.678 0.25 288 0.5 ) 14 )
(( -25.98076211 -15 -140.98 0 0 31.678 0.25 288 0.5 ) 15 )
(( -21.21320344 -21.21320344 -140.98 0 0 31.678 0.25 288 0.5 ) 16 )
(( -15 -25.98076211 -140.98 0 0 31.678 0.25 288 0.5 ) 17 )
(( -7.764571353 -28.97777479 -140.98 0 0 31.678 0.25 288 0.5 ) 18 )
(( -5.51317E-15 -30 -140.98 0 0 31.678 0.25 288 0.5 ) 19 )
(( 7.764571353 -28.97777479 -140.98 0 0 31.678 0.25 288 0.5 ) 20 )
(( 15 -25.98076211 -140.98 0 0 31.678 0.25 288 0.5 ) 21 )
(( 21.21320344 -21.21320344 -140.98 0 0 31.678 0.25 288 0.5 ) 22 )
(( 25.98076211 -15 -140.98 0 0 31.678 0.25 288 0.5 ) 23 )
(( 28.97777479 -7.764571353 -140.98 0 0 31.678 0.25 288 0.5 ) 24 )
(( 30 -7.35089E-15 -140.98 0 0 31.678 0.25 288 0.5 ) 25 )
please send response on sree.kaysthagir@hud.ac.uk
sonnet is offline   Reply With Quote
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 17:18
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 06:42
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 11:44
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
