February 2, 2017, 11:18 |
DPM Injection from file
Rep Power: 9 |
Hi everyone,
I'm currently trying to load a .txt-file into Fluent to get my injection and my simulation running. If I try to list my file, there isn't any output, except: Particle streams from injection-0: STREAM ...........................INITIAL VALUES........................... NO TYP (X) (Y) (Z) (U) (V) (W) (T) (DIAM) (MFLOW) 4 particles not found in injection injection-0 I've have attached my .txt-file. I have read that the first line with the (x y z u v w etc) should be removed, doesn't work either. Should the .txt-file be coded in ASCII or somethin else? Could any of you guys please help me out? Thanks Tim |
February 3, 2017, 11:47 |
#2 | |
amirhossein
Rep Power: 11 |
change the file format from *.txt to *.inj good luck
amirhosseinfardi94@gmail.com |
February 4, 2017, 12:50 |
Rep Power: 9 |
February 4, 2017, 14:21 |
#4 | |
amirhossein
Rep Power: 11 |
remember to change type to inj format
March 6, 2018, 12:00 |
Dpm injection file
nirjhor
Rep Power: 11 |
can anyone helpme out here.what is wron with this file. it is not working
(( x y z u v w diameter temperature mass-flow ) name ) (( 30 0 -140.98 0 0 31.678 0.25 288 0.5 ) 1 ) (( 28.97777479 7.764571353 -140.98 0 0 31.678 0.25 288 0.5 ) 2 ) (( 25.98076211 15 -140.98 0 0 31.678 0.25 288 0.5 ) 3 ) (( 21.21320344 21.21320344 -140.98 0 0 31.678 0.25 288 0.5 ) 4 ) (( 15 25.98076211 -140.98 0 0 31.678 0.25 288 0.5 ) 5 ) (( 7.764571353 28.97777479 -140.98 0 0 31.678 0.25 288 0.5 ) 6 ) (( 1.83772E-15 30 -140.98 0 0 31.678 0.25 288 0.5 ) 7 ) (( -7.764571353 28.97777479 -140.98 0 0 31.678 0.25 288 0.5 ) 8 ) (( -15 25.98076211 -140.98 0 0 31.678 0.25 288 0.5 ) 9 ) (( -21.21320344 21.21320344 -140.98 0 0 31.678 0.25 288 0.5 ) 10 ) (( -25.98076211 15 -140.98 0 0 31.678 0.25 288 0.5 ) 11 ) (( -28.97777479 7.764571353 -140.98 0 0 31.678 0.25 288 0.5 ) 12 ) (( -30 3.67545E-15 -140.98 0 0 31.678 0.25 288 0.5 ) 13 ) (( -28.97777479 -7.764571353 -140.98 0 0 31.678 0.25 288 0.5 ) 14 ) (( -25.98076211 -15 -140.98 0 0 31.678 0.25 288 0.5 ) 15 ) (( -21.21320344 -21.21320344 -140.98 0 0 31.678 0.25 288 0.5 ) 16 ) (( -15 -25.98076211 -140.98 0 0 31.678 0.25 288 0.5 ) 17 ) (( -7.764571353 -28.97777479 -140.98 0 0 31.678 0.25 288 0.5 ) 18 ) (( -5.51317E-15 -30 -140.98 0 0 31.678 0.25 288 0.5 ) 19 ) (( 7.764571353 -28.97777479 -140.98 0 0 31.678 0.25 288 0.5 ) 20 ) (( 15 -25.98076211 -140.98 0 0 31.678 0.25 288 0.5 ) 21 ) (( 21.21320344 -21.21320344 -140.98 0 0 31.678 0.25 288 0.5 ) 22 ) (( 25.98076211 -15 -140.98 0 0 31.678 0.25 288 0.5 ) 23 ) (( 28.97777479 -7.764571353 -140.98 0 0 31.678 0.25 288 0.5 ) 24 ) (( 30 -7.35089E-15 -140.98 0 0 31.678 0.25 288 0.5 ) 25 ) please send response on sree.kaysthagir@hud.ac.uk Last edited by sonnet; March 6, 2018 at 12:28. Reason: for contact |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 17:18 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 06:42 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
