Weld surface deformation by VOF model
Like Tree1Likes
  • 1 Post By minhaj_iut
Old   February 12, 2011, 08:23
Default Weld surface deformation by VOF model
Md. Minhaj Alam
minhaj_iut is on a distinguished road
Dear All,
I am trying to track the weld surface deformation with the help of VOF model. I am considering a 3D transient model where laser beam is striking on the metal surface as heat source. I have written a UDF for this heat source. It works well. For melting the surface, solidification/melting model has been incorporated. Now I would like to track the VOF model. But I am confused how the computational domain should look like for VOF model? For tracking surface deformation, do I need to write any udf for surface tension/forces? In my model, I am not considering key hole. Any advice will be highly appreciated.
Regards
Minhaj
anoop.k.unni likes this.
minhaj_iut is offline   Reply With Quote
Old   March 11, 2016, 06:46
Default UDF for Laser Weld
Lokesh Reddy
Lokesh_Reddy is on a distinguished road
HI
I'm simulating the laser weld to study weld pool behavior like marangoni effects and temperature gradients from weld region to the cooler region . Can anybody with prior experience have written any UDF for moving Heat source and for the simulation for the marangoni effect in the weld pool.
Lokesh_Reddy is offline   Reply With Quote
Old   March 11, 2016, 06:49
Lokesh Reddy
Hi der, could share your udf so that I can get an idea how to start writting for my simulation purpose
Old   March 17, 2016, 04:57
Default UDF moving laser heat source
Piyush
piyupant is on a distinguished road
Friend, if you are looking for DEFINE_SOURCE, here is the UDF for moving gaussian profile laser.
#include "udf.h"
#include "unsteady.h"
#define ETA 0.25
#define POWER 1000.0
#define PI 3.14156
#define RQ 0.0005 /* radius of laser beam */
DEFINE_SOURCE(energy_source, c, t, dS, eqn)
/*This checks whether the cell is within laser beam span- if inside put intensity else zero intensity */
real source;
real x[ND_ND];
real rmag,rmag1;
C_CENTROID(x,c,t);
x[0]=x[0]+0.015*CURRENT_TIME;
rmag=(x[0])*(x[0])+(x[2])*(x[2]);
rmag1=sqrt(rmag);
if( x[1]<0.0 && x[1]>0-0.001)
if( rmag< RQ )
source = (ETA*POWER)/(PI*RQ*RQ)*exp(-2*rmag1*rmag1/(RQ*RQ));
else
source = dS[eqn]= 0.0;
else
source =0.0;
return source;
piyupant is offline   Reply With Quote
Old   February 8, 2017, 03:24
ARJUN A ASOK
ARJUN A ASOK is on a distinguished road
when i run this code it is shown " recieved a fatal signal (segmentation fault) " .
Is there any way out
ARJUN A ASOK is offline   Reply With Quote
Old   February 26, 2017, 23:51
Aaronaiy
Aaronaiy is on a distinguished road
#include "udf.h"
#define ETA 0.25
#define PI 3.14156
real source;
real x[ND_ND];
real rmag,rmag1;
C_CENTROID(x,c,t);
rmag1=sqrt(rmag);
if( rmag< RQ )
else
else
source =0.0;
return source;
Hello, did you do some simulation about the evaporation involved in the welding?
Aaronaiy is offline   Reply With Quote
Simplified VOF Model gulbenkian FLUENT 1 June 10, 2010 16:52
Surface Tension Force Model Miguel CFX 7 October 2, 2006 05:30
A Problem with setting the time step in VOF model Le FLUENT 2 July 20, 2006 22:00
free surface of VOF and melting model? wanghong FLUENT 3 March 13, 2006 09:57
Surface Tension Gradient of VOF model Ray FLUENT 1 February 22, 2000 21:45
