Syed
Rep Power: 9 ![]() |
I want to simulate a turbine blade. However, I don't want to give rotational velocity to the blade. I want to give the inlet velocity and let the wind itself make the blade rotate. I have come across some suggestions that writing UDF is the solution. I have done some tutorials on UDF but I am unable to write. Can someone please tell me the entire UDF program for this problem??
turbine blade, udf and programming |
Fluent sopenoutputfile error message | em07189 | FLUENT | 2 | November 11, 2019 08:08 |
[ANSYS Meshing] negative cell volume detected while running ANSYS Fluent UDF | khushbu.bhavsar92 | ANSYS Meshing & Geometry | 6 | April 14, 2016 15:50 |
sinusoidal horizontal translation udf in ansys fluent | shivshankarnair | FLUENT | 1 | September 19, 2014 06:40 |
Ansys FLUENT UDF - Velocity profile (of known values) across edge / surface | emmkell | Fluent UDF and Scheme Programming | 2 | October 21, 2011 13:12 |
Ansys FLUENT UDF - Velocity profile (of known values) across edge / surface | emmkell | FLUENT | 0 | October 20, 2011 07:37 |
