How fluent calculate the pressure by velocity profile? |
March 10, 2017, 11:14 |
Marco Ghiani
Rep Power: 15 |
Hi there !
I've got a question .. I have a inlet profile for a turbine blade, (by experimental result) , now ... I have to use pressure inlet boundary (rightnow I've put the velocity profile and run simulation for a while .. then i write the PRESSURE profile and change the boundary to pressure inlet ... ) Now the question is .. if I want know which pressure profile without using this "tricks" ?? consider that the velocity at the inlet surface is 20 ~ 40 m/s how can i calculate it ? Thanks in advance |
March 10, 2017, 15:20 |
#2 | |
Lucky
Rep Power: 66 |
Alternatively you can start to make some assumptions about the problem, but this is just a way of turning off the physics. |
how to put udf inlet velocity and udf outlet pressure in fluent | raminostadi | Fluent UDF and Scheme Programming | 4 | July 3, 2017 06:43 |
Straight Pipe with imported velocity profile. Pressure gradient? | Ahuja.Darsh | FLUENT | 7 | September 13, 2016 08:11 |
Fluent & CFD code calculate Static pressure | vhcongtltd | FLUENT | 0 | November 2, 2013 08:24 |
Fluent & CFD code calculate Static pressure | vhcongtltd | ANSYS | 0 | November 2, 2013 08:22 |
Variables Definition in CFX Solver 5.6 | R P | CFX | 2 | October 26, 2004 02:13 |
