Problems for simulating PEMFC using fluent module
Like Tree1Likes
  • 1 Post By beehuah
Old   April 9, 2014, 04:19
Default Problems for simulating PEMFC using fluent module
Jie
slan89 is on a distinguished road
I am using a Fluent module to simulate a 3D single channel PEMFC, and I believe I have got a converged solution. But when I display the h2o distribution contour of a cross section. I got some weird results.
As shown in the figures, the h2o fraction of the current collector area is not 0, however, it is solid. And the 8 corners of current collector is weird, too.
Please give me a reply if someone know why this should be. Thanks a lot!
slan89 is offline   Reply With Quote
Old   October 17, 2014, 07:51
A CFD free user's Avatar
A-A Azarafza
A CFD free user is on a distinguished road
Dear friend,
No problem regarding your modeling. I suppose you should uncheck the "global range" option in contours window. Try it and it will be OK.
May I use this place and ask you a question?
P.S. Do you have any experience in two dimensional (2D) simulation of PEM fuel cell using PEMFC module?
Regard yours
A CFD free user is offline   Reply With Quote
Old   March 7, 2016, 01:24
beehuah is on a distinguished road
I'm currently working on 3D single cell PEMFC with add on PEMFC module in ANSYS 15. The simulation are not converging and error occured where divergence were detected in amg solver. I have made the simulation setting based on single channel tutorial but amg solver divergence were detected in temperature. When i lower the URF for energy, the divergence happen to X-momentum. When i lower the X-momentum termination restriction the temperature are having divergence back. Do anyone know what is the problem here? Is it due to the mesh generated from meshing that were not totally uniform? I have tried to generate mesh from ICEM but im not familiar with ICEM the mesh generated were not in good shape and I have the same problem with FLUENT by using mesh generated from ICEM.
Moreover, the value of I-cathode generated on 1st iteration are showing very high value before the divergence error prompt up. Why would this occur? Hope that I could get some guidance here. I'm stuck with this problem for months and I have no idea what should I do to resolve it. Thank you in advance.*
https://drive.google.com/file/d/0B04...ew?usp=sharing
P.S:I have refine the model and mesh generation were uniform but not perfect due to limitation of meshing in ANSYS.
Sunil89088 likes this.
beehuah is offline   Reply With Quote
Old   April 10, 2016, 05:42
ovi_1211 is on a distinguished road
Same error I am getting. If you can get a solution please help.
ovi_1211 is offline   Reply With Quote
Old   March 16, 2017, 05:53
Ramakant Gadhewal
Location: Chemical Engineering,National Institute of Technology,Warangal (T.S.),India
ramakant is on a distinguished road
Dear
You can change the value of Under relaxation factors(URFs):
Reduce the following under-relaxation-factors:
Pressure 0.5-0.7
Momentum 0.3
Protonic potential 0.95-0.99
Water content -0.95
This will help?
Regards
Ramakant
ramakant is offline   Reply With Quote
[ICEM] Problems with export 2D mesh from ICEM to FLUENT newcomer ANSYS Meshing & Geometry 54 September 20, 2014 12:40
[ansys fluent] problems of running ANSYS 12.1 fluent module mkwang2006 FLUENT 3 September 30, 2013 10:59
Problems with FLUENT MPI on i7 2600K/P8P67 TaurusASV FLUENT 1 May 5, 2011 11:58
Problems with Fluent Jacek Main CFD Forum 2 August 16, 2002 04:14
Using Fluent for Geophysical Problems Hassid Samuel FLUENT 0 February 23, 2001 06:04
