[Sponsors] | |||||
Periodic BC in a cylinder embedded fluent flow |
kshitiz
Rep Power: 10 ![]() |
Hi Every one,
So i was working on this project where a cube is embedded with 6 cylinders. the dimension of a cube is 500x500x500 micrones And the cylinder be 5 micrones in dia and atleast 200 micrones long in any of the one dimension. So i want to make 2 opposite face of a cube periodic bc. ((Opposite face not containing cyinders)). Any 2 opposite face will do. I guess i did match control mesh alright of opposite faces but when i enter the periodic bc codes on fluent it reads Error: Failed to make zones periodic. Error Object: #f I assigned the coordinate system on the center of the cube any my cylinder are in opposite y-direction. And for the mesh match control i have used: Transformation- cyclic axis of rotation-co ordinate system
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Flow past a 2D cylinder - High Re (1E+05) - Cd too high | Pervispasco | OpenFOAM Running, Solving & CFD | 4 | March 14, 2022 03:19 |
| Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 07:40 |
| [Commercial meshers] converting Fluent mesh to openfoam standard mesh | deepesh | OpenFOAM Meshing & Mesh Conversion | 31 | March 29, 2017 06:59 |
| Flow over an elastic mounted cylinder in Ansys fluent | rahilvalani | FLUENT | 0 | May 11, 2016 20:29 |
| [ICEM] Periodic condition between ICEM and FLUENT | Touré | ANSYS Meshing & Geometry | 0 | August 5, 2012 18:00 |
