Flow and heat transfer across a periodic array of cylinders.
Old   April 4, 2017, 15:54
Default Flow and heat transfer across a periodic array of cylinders.
M. Asif
Ashley_114 is on a distinguished road
I am simulating a 2D triangular array of periodic cylinders for flow and heat transfer calculations,the flow is in y direction and diameter of the cylinders is 1m, my results are not matching with standard results ,also i am a bit confused about the reference area and length, please throw some light on my problem.
I am attaching figure of my array.
Thanks
Ashley_114 is offline   Reply With Quote
2d flow across an array, 2d flow around cylinder
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 01:27
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 05:15
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
