Who can fix the error on this UDF code???
Old   May 9, 2017, 03:43
Default Who can fix the error on this UDF code???
NPs
NPs is on a distinguished road
Hi everyone, I have to implement a UDF in fluent as a Wall Heat Generation Rate Profile on this geometric model
The wall heat generation must be in the wall of the inner cylinder
and it's defined by these 2 equations
T = (((mu_0)*3,14*(chi_2)*(frequency)*(magnetic_field_ quadrato))/(((mass_NPs)*(cp_NPs))+(cp_water)*(mass_water)))*t ;
real source = ((mass_NPs)*(cp_NPs))+(cp_water)*(mass_water))* T;
I got T then i got real source,the others are parameters with numeric values.
I wrote this code for the UDF
#include "udf.h"
#define mu_0 1,256637*10^(-6) // permeabilitą elettrica vuoto (H/m)//
#define chi_2 1,25 //suscettivitą magnetica
#define frequency 344000 //frequenza campo
#define magnetic_field_quadrato 21000 //campo magnetico
#define mass_NPs 1.5 //massa nanoparticelle
#define cp_NPs 0.67 //calore specifico nanoparticelle
#define mass_water 498.5 //massa acqua
#define cp_water 4.18 //calore specifico acqua
DEFINE_PROFILE(wallheatgenerate,thread,i)
real t = CURRENT_TIME
delta_T = (((mu_0)*3,14*(chi_2)*(frequency)*(magnetic_field_ quadrato))/(((mass_NPs)*(cp_NPs))+(cp_water)*(mass_water)))*t ;
real source = ((mass_NPs)*(cp_NPs))+(cp_water)*(mass_water))* T;;
face_t f;
begin_f_loop(f,thread)
F_PROFILE(f,thread,i) = source;
end_f_loop(f,thread)
Then i got this error "f:undeclared variable" and "parse error" on these lines
15 delta_T = (((mu_0)*3,14*(chi_2)*(frequency)*(magnetic_field_ quadrato))/(((mass_NPs)*(cp_NPs))+(cp_water)*(mass_water)))*t ;
16 real source = ((mass_NPs)*(cp_NPs))+(cp_water)*(mass_water))* T;;
17 face_t f;
Anyone can help me to fix it?
Thanks a lot
NPs is offline   Reply With Quote
Old   May 9, 2017, 07:12
Kevin
KevinZ09 is on a distinguished road
Quick scan, so no sure if this is your only problem, but replace the "," by "." for decimals, i.e., write 3.14 instead of 3,14. There are a couple of occurences of this error.
KevinZ09 is offline   Reply With Quote
Old   May 9, 2017, 08:02
KaLium's Avatar
Kal-El
KaLium is on a distinguished road
; instead of ;;
"real t = CURRENT_TIME" needs "; "
KaLium is offline   Reply With Quote
Compiling the customized UDF code for PEMFC dmfo Fluent UDF and Scheme Programming 2 October 1, 2017 18:30
UDF code help solve reaction rate equation palm oil zirkov Fluent UDF and Scheme Programming 0 February 13, 2017 10:34
write code UDF Fluent solve kinetic reaction rate equation palm oil zirkov FLUENT 0 February 13, 2017 10:16
Difficulty with UDF code for HEAT FLUX etudiant_IITB Fluent UDF and Scheme Programming 1 December 7, 2015 08:07
