Need help:: condensation in vertical square minichannel |
May 18, 2017, 05:59 |
Diksha
Rep Power: 9 |
Could anyone please help me on the below? I am trying to simulate the condensation of water vapour in a vertical square minichannel on fluent.
I am using implicit VOF, steady state, standard k-e model, energy on and Lee model, gravity on and surface tension added. My BCs are: inlet: mass flow rate, turbulence intensity, hydraulic diameter, temperature outlet: pressure outlet, turburlence intensity, hydraulic diameter and backflow temp 0. at walls: stationary and temp imposed and symmetric bcs on two sides. The problem is: every time my simulation diverges (in temperature or VOF-1). I have checked my mesh and the skewness is 0 and orthogonal quality is 1. So i think the mesh is good. I have used under relaxation factors, still it diverges. Could you please help me? Maybe am missing something. I don't know... Thanks a lot... quite desperate with this.. please help Diksha |
Root mean square in Fluent, it is probably not genuine! | micro11sl | FLUENT | 8 | October 16, 2020 01:34 |
How accurate can CFX model condensation? | JuPa | CFX | 7 | January 20, 2019 17:17 |
Thin Film Condensation on Vertical Plate in Laminar Flow | AdrianVici | Fluent Multiphase | 1 | May 19, 2017 00:51 |
Condensation and evaporation on vertical wall | CFDlearn | Fluent Multiphase | 0 | September 7, 2016 14:34 |
Condensation on a vertical wall | Yvonne | FLUENT | 0 | May 5, 2005 20:55 |
