Particle injection
Old   August 6, 2005, 12:17
Default Particle injection
Mazyar
Hi.
I am going to inject some particles into an air flow in a duct which has one inlet and two outlets. The outlet ducts have diffetent sizes, so I want to see what portion of the particles go in each outlet. The size and mass of particles can be ignored in case can simplify the things.The problem may be steady state or transient. Could somebody kindly tell me what is the best way to simulate the injection of the particles?
Thanks, Mazyar
Old   August 6, 2005, 14:20
Default Re: Particle injection
pUl|
Discrete phase model. Transient. If the behavior is steady state, it will show up.
Old   August 10, 2005, 08:30
John
Mazyar,
I am studying a similar model. I am calculating the fraction of discrete particles travelling through a side arm on a T junction.
I can simulate it, but need to know the mass fraction through each outlet.
Do you have a good method to calculate the relative fraction of particles travelling through each outlet?
Thanks
john.
Old   August 10, 2005, 11:55
Mazyar
John,
I think, you must specify the type of both outlets as OUTFLOW. By doing this, FLUENT will calculate the fraction at each exit.
Mazyar
Old   May 22, 2017, 17:01
Default Deposition Particle coordinate
Anu
n9879005 is on a distinguished road
I am working on Aerosol Particle deposition in the specific region of human lungs. At this stage I am struggling on How to get deposited (or trapped) particle coordinates in fluent. Your help would me much appreciated. Thanks in advance.
Anu
QUT
n9879005 is offline   Reply With Quote
Particle Injection Mass Flow Rate and Position leonozx FLUENT 3 March 9, 2018 09:58
Particle injection boundary condition fjalil CFX 8 September 23, 2009 09:40
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
Particle Injection File or DEFINE_DPM_INJECTION_IN Dave FLUENT 0 January 18, 2008 13:16
Particle velocity - Injection With Line Weighting Danuta CFX 0 October 10, 2007 06:21
