Multiple cell zones in FLUENT
Old   September 8, 2011, 18:55
Default Multiple cell zones in FLUENT
Adam
bluemonkee is on a distinguished road
I am trying to create multiple cell zones so that I can have different porosity in each zone. This is a 2-D asymmetric model, and I generated the mesh using Ansys's Design Modeler and Meshing tools. Right now, I can get several zones, but FLUENT is requiring that the lines between each zone has its own boundary condition (FLUENT has assigned all of these lines names that begin with "surface_"). Is there a way to remove the surfaces from the model in FLUENT? Or is there a better way to use the ANSYS tools to create a multiregion model?
Thanks for your help!
bluemonkee is offline   Reply With Quote
Old   November 1, 2011, 09:57
rohit mukare
rohit.mukare7 is on a distinguished road
hi i am also facing the same problem.plz let me knw if u could solve that..
rohit.mukare7 is offline   Reply With Quote
Old   November 3, 2011, 10:38
Oyster
CFD_rocks is on a distinguished road
I am also having the same problem, any one got an idea?!
CFD_rocks is offline   Reply With Quote
Old   November 5, 2011, 09:29
Zachariah Swetky
swetkyz is on a distinguished road
If I understand correctly, you are just trying to get all of the zones to behave as one continuous fluid domain. Ideally, you would want to generate a conformal mesh, which you can do by making all of your zones one 'part' in Design Modeler. You can do this by selecting them and right clicking then selecting "form new part".
To connect the fluids at the interfaces, you need to merge the two surfaces at each interface (between fluid zones). To do this go to 'Mesh Interfaces' under 'Problem Setup' in the menu bar on the left. It is fairly straightforward from there.
Hopefully this helps.
-Zachariah
swetkyz is offline   Reply With Quote
Old   November 8, 2011, 07:24
Oyster
Thanks, it did help a lot!
Old   January 20, 2013, 05:11
Default How to go about it?
Troll_Warlord
sumanth_0811 is on a distinguished road
Can anyone help me with the creation of multiple zones during meshing?
Is there a tutorial for that?
sumanth_0811 is offline   Reply With Quote
Old   March 5, 2013, 01:25
fn1743 is on a distinguished road
how do i draw a 2D block capable of being split into two zones? I need to create a free surface in a tank.
thanks
fn1743 is offline   Reply With Quote
Old   November 13, 2013, 07:23
Dimitris Romanas
Volumeoffluid is on a distinguished road
-Zachariah
Hi Zachariah,
so i did exactly what you say, but what i should define this line between two fluids??as interface??or as moving wall?
Thank you in advance!
Volumeoffluid is offline   Reply With Quote
Old   May 8, 2016, 09:22
Default Mark and patch
hamid-nice is on a distinguished road
Hello Dears
I have a pipe with oil and a water droplet is in the middle of it
I use of "Form New part" and solve my Boundary condition where I have a boundary for droplet as interior
But there is a problem now:
there is not in the mark list for marking for patching because it is interior type now
it gose to control switch
how can I patch the interior droplet for define only one phase (water) for it ?
regard
hamid-nice is offline   Reply With Quote
Old   May 10, 2016, 11:34
Xi Chen
kevinxichan is on a distinguished road
Originally Posted by hamid-nice View Post
Hello Dears
regard
What I did for droplet sliding on a solid surface was
1. draw the chamber/channel in design modeler without the droplet
2. mesh it
3. in fluent, adapt the region you want to put a droplet and mark it
4. patch the adapted region to the secondary phase(i.e. water)
kevinxichan is offline   Reply With Quote
Old   May 10, 2016, 14:42
Default answer
  #11
hi Dear kevinxichan
I don't want to use of mark regine in fluent because I want to use of different tyes of shape of droplet like elilp or other nontipically shape so I think it is not possible with this switch so I should model it with other software and import to fluent
regard
Old   May 26, 2016, 09:50
Default check patched
  #12
Dear kevinxichan
I try your suggestion
I marked and patched the second phase (water droplet)
before runing and calculating , I only can see the regine patched with management register window
but it can not show the phases in contour when i choose phases
when i click on display button in contour window
Question : must I see the regin patched before calculation ?
how can check the patch before calculation ? why can not I see in contour now ?
regard
Old   December 12, 2016, 16:59
Xi Chen
Have you solved your problem yet? I'm sorry that I haven't checked this forum for half a year.
Old   December 13, 2016, 11:15
hi dear
Thank you for attention
yes , I solved my problem
Old   May 23, 2017, 00:02
Ken
kennyboy is on a distinguished road
-Zachariah
Hi there
Where exactly do you do the merging of two surfaces? I cant seem to find the problem setup menu nor the mesh interfaces option. There is only solution setup in fluent.
kennyboy is offline   Reply With Quote
boundary condtions, multiregion, porous, surface, zones
FvMatrix coefficients shrina OpenFOAM Running, Solving & CFD 10 October 3, 2013 14:38
Cell centered vs Nodal Data from Fluent prikeyma FLUENT 0 September 1, 2010 11:40
Cell index in fluent Naresh FLUENT 0 May 9, 2007 15:56
Warning 097- AB Siemens 6 November 15, 2004 04:41
Inputs for porous zones in FLUENT Roel van Os Main CFD Forum 1 September 1, 1998 12:41
