May 28, 2017, 11:51 |
Tray distillation column - CFD model Fluent
Galih Bangga
Rep Power: 14 |
Dear Everybody,
Please let me know if the topic/thread does not fit into the category. I am Galih from Stuttgart. I am new in the simulations for multi-phase flow (my original topic is actually aerodynamics of wind turbines). Currently I am trying to model a distillation channel incorporating "tray distillation column" in the system. My question is: Is there any "model" that can be used for the "tray distillation column" in Ansys Fluent or should I fully resolve the mesh of the structure? If the latter is the case then I belive that the computational cost is so expensive. Thank you for considering this question and I look forward to receiving your recommendation. Cheers, Galih |
May 29, 2017, 07:55 |
D. N. Venturi
Rep Power: 13 |
As I see it, there is essentially two ways of modeling a distillation sieve tray: VOF or Euler-Euler.
For a VOF simulation, your mesh would have to be fine enough to model the bubbles. (very expensive) For the Euler-Euler you'll model a mixture of the phases. Check this out: http://www.sciencedirect.com/science...85894707001659 |
distillation, evaporation, fluent, multiphase, species |
Integration of a Custom C++ Model into FLUENT | Syed Haider | FLUENT | 2 | March 6, 2018 23:37 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
Can evaporation-condensation model used to simulate distillation column? | Bin | ANSYS | 0 | May 23, 2013 07:53 |
Reynolds Stress model in CFX vs Fluent | Tim | CFX | 1 | October 7, 2009 06:19 |
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model | Jonas Larsson | FLUENT | 5 | March 13, 2000 03:27 |
