July 12, 2017, 05:15 |
Gmsh and Fluent 6.3
Filippo
Rep Power: 8 |
Hello, how to use Gmsh mesh on Fluent 6.3? Ideed Gmsh can't generate .cas file...
July 12, 2017, 07:45 |
Michael Prinkey
Rep Power: 25 |
Gmsh and Gambit produce .msh files. Those contains only the mesh geometry data and face patches used for boundary conditions. You import the .msh file into Fluent and create the .cas file. That will contain flow information (like density, pressure, velocities at boundary conditions), model types, etc. along with the mesh date.
Good luck. |
July 12, 2017, 08:02 |
#3 | |
Arjun
Rep Power: 34 |
I think the .msh produced by Gmsh is different and is based on finite element data. There seem to be no converter so I am going to write one in coming days as I get time because for FVUS it is easier to work with Fluent format and many people can use this converter (as opposed to me converting it to FVUS format directly). This is planned but I keep putting off in favour of other things. Unfortunately it is no help as of now. |
July 13, 2017, 00:13 |
Michael Prinkey
Rep Power: 25 |
You can try to OpenFOAM's convesion tools. You can convert the gmsh .msh file to OpenFOAM (gmshToFoam) and then convert the OpenFOAM mesh to a Fluent .msh file (foamMeshToFluent) and see what happens.
July 22, 2017, 10:57 |
Filippo
Rep Power: 8 |
Ok, thanks everyone. FVUS is free?
July 22, 2017, 14:51 |
Lucky
Rep Power: 66 |
July 15, 2019, 10:12 |
zizhou huang
Rep Power: 6 |
It works, thank you! Besides, I still have problems with boundary conditions. The physical surfaces I set in Gmsh is missing after transformed into .msh for fluent. Could you tell me how to handle this?
July 19, 2019, 04:44 |
Rep Power: 9 |
An alternative solution could be to export nastran bulk data file from gmsh to suddenly import it on fluent.
However, I've noticed that this doesn't work for some of the linux Fluent releases. |
July 22, 2019, 23:31 |
#9 |
Arjun
Rep Power: 34 |
June 15, 2022, 23:46 |
#10 | |
Abdoul
[Gmsh] Gmsh geometry into Fluent | Kelda | OpenFOAM Meshing & Mesh Conversion | 0 | September 13, 2016 07:50 |
convertion of openfoam .msh file to fluent | pankos | OpenFOAM | 4 | December 21, 2015 12:30 |
[Gmsh] Gmsh to fluent? | lordvon | OpenFOAM Meshing & Mesh Conversion | 2 | October 4, 2014 05:10 |
FLUENT boundary condition problem with gmsh | EIvb | FLUENT | 0 | April 30, 2013 07:45 |
From Gmsh to Fluent | masuarez | FLUENT | 1 | February 23, 2012 11:45 |
