particle time step size, number of time steps in DPMPM
Like Tree1Likes
Old   May 5, 2012, 04:55
Default particle time step size, number of time steps in DPMPM
leila
lili is on a distinguished road
hi
i want to solve a DPM problem with unsteady particle tracking. in discrete phase model panel what is the "particle time step size (s)" and "number of time steps"?
is "particle time step size" related to length scale/step length factor? I have been confused because I dont know how fluent track particles unsteady in an steady contineous flow field
please help.
BlnPhoenix likes this.
lili is offline   Reply With Quote
Old   May 5, 2012, 08:31
Amir's Avatar
Amir
Amir is on a distinguished road
Dear Leila,
The particle trajectories are computed with lagrangian approach; i.e., particle paths are computed via unsteady integration here which obviously needs time step size and number of them but there is a restriction here that a particle cannot jump over a cell in its path. you can implicitly set time step with specifying length scale or step length factor which is a successive number of iteration that particles remain in one cell; you can also deactivate automation and provide time step size explicitly which suggested in specific goals.
Bests,
Amir
Amir is offline   Reply With Quote
Old   May 6, 2012, 03:05
leila
Dear Amir
As I understand from the help the "length scale" is the distance that the particle will travel before its motion equations are solved again and its trajectory is updated and the "step length factor" is the number of time steps required to traverse the current continuous phase control volume. So why you say "cell"?
And I want to know in discrete phase model panel what is the difference between length scale/step length factor (bellow the tracking parameters) which control time step size and "particle time step size" (bellow particle treatment) which appears when unsteady particle tracking is ticked.
Also in particle treatment field what does "number of time steps" means? In help said "When you increase the Number of Time Steps, the droplets penetrate the domain faster"???
Old   May 6, 2012, 07:07
Amir's Avatar
Amir
yes, that's right! the current cell (computational cell) is the current control volume the particle is there.
These are 3 different ways for setting particle time step in steady/unsteady tracking. (refer to the unsteady particle tracking section of manual)
yep, that's the number of particle advancement in the domain. (number of integration)
Bests,
Amir
Old   May 8, 2012, 02:10
leila
Dear Amir
Thanks for your helpful guide. but I cant fully understand the procedure fluent uses to solve a coupled problem in which contineous phase is steady and particle tracking is unsteady. I think fluent first solves the contineous flow field and then in t=0 injection and particle tracking occurs then depend on "Number of contineous phase iteration per DPM iteration" some iteration for contineous phase are done and then again injection. but how long is each injection? I think it is "particle time step size"*"number of time steps" am I right?and another question: what happens if "update DPM sources every flow iteration" is ticked?
Old   May 8, 2012, 15:06
Amir's Avatar
Amir
Exactly, but note that these are not necessarily new injections! these can be advancements of previously injected particles.
The effects of particles on flow field are computed more realistically in each time step but in steady flow fields it can just affect the required time for convergency.
Bests,
Amir
Old   May 9, 2012, 01:03
leila
hi
yani age "update DPM sources every flow iteration" tick bekhore convegence behtar mishe? ye soale dige: shoma az openfoam chizi midunid? nesbate be fluent che mazaya va eibhaee dare?
thanks
Old   May 9, 2012, 10:01
Amir's Avatar
Amir
Dear Leila,
Generally, It can reduce convergence time but it may cause other issues.
yes, I've done few projects with it specially in viscoelastic field. it's not very user friendly but you'll like it at last. It's not fair to compare openFOAM with FLUENT . OpenFOAM is much more powerful that FLUENT in all aspects and it's also open source.
Bests,
Amir
Old   November 21, 2012, 13:27
Mina
kingpots is on a distinguished road
Dear Amir and Leila ,
The above mentioned clarifications helped me a lot in understanding lots of issues related to the DPM , however i still have some concerns , kindly bear with the following :
- If my injection flow rate is 1.5 g/s and particle time size is 0.001 (unsteady tracking ) No. of time size =1 i.e. the pulse of the injection will be short (1*0.001 ) the start and stop time of the injection was set to 0 -300 sec. and the no. of particles is 60 droplets
1) Fluent at each DPM injection is injecting the 1.5E-3 which is 1.5 *0.001 and this no. is not increasing , why ???
2) As you said (Amir ) the Update DPM option is really affecting the convergence time , but what i don't understand is the relation btw that option and the famous graph of URF interphase exchange terms
3) in the best practice guide : they are saying to reduce the URF of DPM and increase the no of continous iterations per DPM iterations , which is totally contradictory with the 2 way couple strategy and to the above mentioned graph . i.e for the results to take effects URF of DPM should be increased and the no. of iterations to be reduced
Can you please advise , since i can tell that you are seniors in the DPM sub-model
Thanks in advance
kingpots is offline   Reply With Quote
Old   January 24, 2014, 07:42
ruturaj171 is on a distinguished road
aamir sir can you please tell me what is exact meaning of stop time in the set injection properties in the fluent? for micron size water droplet what should be its value? is it really affecting the simulation results?
ruturaj171 is offline   Reply With Quote
Old   January 24, 2014, 08:51
Amir's Avatar
Amir
Actually these variables are described in the manual if you can take a look. You can set how the particles are injected in your domain. This happens between "start time" and "stop time"; this is a physical BC regardless of the particle type!
Bests,
Amir
Old   January 24, 2014, 12:34
Thank you sir for your quick reply.
Sir my problem is evaporation of 10 micrometer droplet in air (continuous phase). So i did "injection type" as a 'surface' with injection from velocity inlet BC. "the particle type" I have taken as 'inert' and "material" as 'water liquid' then i set point properties. Have set problem correctly? In theory guide of fluent about 'start' and 'stop times' they gven Injections with start and stop times set to
zero will be injected only at the start of the calculation ( t=0).
' still not clear the meaning.
Thank you sir
Old   January 24, 2014, 14:51
Amir's Avatar
Amir
Sir my problem is evaporation of 10 micrometer droplet in air (continuous phase). So i did "injection type" as a 'surface' with injection from velocity inlet BC. "the particle type" I have taken as 'inert' and "material" as 'water liquid' then i set point properties. Have set problem correctly? In theory guide of fluent about 'start' and 'stop times' they gven Injections with start and stop times set to zero will be injected only at the start of the calculation ( t=0).' still not clear the meaning.
Thank you sir
I don't have any idea regarding the evaporating particles. I guess you need to change the type to droplet not inert.
In an unsteady flow, the particles can inject over time with a specified time step. For instance, if you set "start time=5" and "stop time=10", injection of particles starts at t=5 s and continues until t=10 s with specified particle time step.
Bests,
Amir
Old   February 27, 2014, 06:43
Amir sir, from your previous posts I understood the exact meaning of 'particle time step size' and 'number of time steps'. About maximum number of steps under tracking parameters I know is 'step length factor * number of control volumes (elements)=maximum number of time steps. Which are these steps? Is there any relationship between particle time step size and maximum number of time steps?
Also suppose in set injection properties we set 'start time=0 sec' and 'stop time =10sec' and if 'particle time step size is 0.1 s' then does it mean 100 iterations per control volume.
In fluent DPM, (for 10 micron droplet case) during iterations , after certain number of continuous phase iterations, there will be 'advancing DPM injections' , so injecting suppose 570 particles with certain mass, is it mean by mass of 570 droplets?
Thank you sir.
Old   February 27, 2014, 10:39
Amir's Avatar
Amir
Actually, what we need in tracking particles are step size and number of steps. When you're setting the particle time step, the step size is specified and the number of steps would be set by considering the current flow field time. However, the time step can be changed if you have decreased the max number of steps as a controlling criterion.
Of course not! Injecting and tracking are completely 2 different concepts!
Depends on the particle properties. If they are droplets, the mass of 570 droplets will be added.
I guess it would be better to take a look at the manual sec. 22.
Bests,
Amir
Old   March 1, 2014, 01:41
Thank you sir,
Can you please tell me which manual ? I have 3 guides, user, theory and tutorial of ansys fluent 14.0 but any of these sec.22 is not related with DPM.
Regards
Old   March 1, 2014, 03:34
Amir's Avatar
Amir
Thank you sir,
Regards
I mean the user guide, DPM section. In the manual of FLUENT 6.3, it's sec. 22.
Bests,
Amir
Old   March 17, 2014, 02:53
Hi Amir Sir
Sir, if I treat the particles in steady fashion, then does it mean that discrete phase equations which are ODEs with time as independent variable will not be solved?
Also in my cooling of heat sink model with water droplets of 10 micrometer, if I reduce the number of continuous phase iterations then domain is overcooled if I increase those it will not happen, so can say that this particular number will directly proportional to certain region of domian (CV) where evaporation will happen because of particle tracking.....
Sir can you suggest me some books or material regarding DPM as from manual I could not clear totally the processes happening in DPM
Regards
Old   March 17, 2014, 05:00
Amir's Avatar
Amir
Hi Amir Sir
No! The DPM equations are solved in unsteady fashion, but they can be considered in steady or unsteady flow fields. These two are different.
Regards
Nope. In each numerical analysis, you should assure the iterations are quite enough and increasing them any further wouldn't change the results. I don't see any proportion ....
You can take a look at any text book in this field; aerosols. For instance, this one:
"Aerosol Technology, William C. Hinds"
Bests,
Amir
Old   April 14, 2014, 09:31
Hi sir
In my heat sink cooling problem actually I want relative humidity of 15% at the exit of the sink but I am getting it 7.42% , I tried with different combinitions of particle time step size and number of time steps. In this particular process I have given mass flow rate of 4.22e-7 and stop time of injection as 100s for every combinition, But still my rate of evaporation and hence RH is not increasing. (In my problem the relative reynolds number is 0, air velocity is 1 m/s). Can you suggest me a way to resolve the problem?
Regards
Ruturaj
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 04:35
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
unsteady calcs in FLUENT Sanjay Padhiar Main CFD Forum 1 March 31, 1999 12:32
