August 8, 2017, 14:36 |
variable Thermal conductivity in Nusselt
NGP
Rep Power: 10 |
Hi
I have laminar nanofluid in a pipe under constant heat flux. I need h.d/k to find the local nusselt number. the thermal conductivity is variable along the pipe. is there any method in ansys fluent / post CFD to calculate the Nusselt along the pipe versus location? (like a xy result) Thanks Navid Sent from my iPad using CFD Online Forum mobile app |
August 9, 2017, 02:57 |
Lucky
Rep Power: 66 |
First you need to figure out how to calculate kref(x,y) and Tref(x,y), and in my opinion these are much more difficult problems.
Assuming you have kref and Tref locally, you can define new field functions inside Fluent or inside CFD post and apply the correction factors. You could also do this externally in excel or your favorite programming language after you have exported the necessary values. However, there's not a simple automatic way to do it. I.e. you can't just tell Fluent to use a reference temperature field and reference conductivity field. Your options in the reference values are limited. |
How to set Variable Thermal Conductivity? | LThomes | CFX | 14 | July 29, 2017 06:27 |
Simple piston movement in cylinder- fluid models | arun1994 | CFX | 4 | July 8, 2016 02:54 |
IAPWS water properties + orthotropic thermal conductivity | Chander | CFX | 1 | February 29, 2012 17:26 |
Inteface thermal conductivity | ado | Main CFD Forum | 4 | March 11, 2002 19:46 |
Info: Short Course On Thermal Design of Electronic Equipment | Arnold Free | Main CFD Forum | 0 | August 10, 1999 10:18 |
