Enough heat is not transferred in heat Exchanger. (Fluent)
Prev Previous Post   Next Post Next
Old   August 11, 2017, 09:40
Default Enough heat is not transferred in heat Exchanger. (Fluent)
Jerol Soibam
Jerol is on a distinguished road
Dear fluent users,
I am modelling a heat exchanger which has hot gas flowing in a innerpipe and a phase change material (PCM) is placed between the inner pipe and outer pipe. I have made sure there is coupling effect between the hot gas and the inner pipe as well as inner pipe and the PCM. The flow inlet is kept at 498 K and the PCM is suppose to melt at a temperature of 391 K. However, i see that the heat goes constant at 380 K at the inner pipe and never rises even if i let it simulate for longer time.
But when i change the hot gas by water as the fluid. It dose the work of melting which means enough heat is being transferred from the fluid to the innerpipe.
So, i wanted to know if anyone has a solution to this problem.
Thank you in Advance.*
Jerol is offline   Reply With Quote
Heat transfer analysis of heat exchanger with complicated shape and irregular fins Mahesh Patil CFX 1 September 29, 2016 12:07
Heat trasfer coefficient in a pipe - Fluent elios FLUENT 1 February 6, 2015 14:18
2D model of a tube in tube heat exchanger in fluent raveesh FLUENT 1 July 9, 2014 08:11
Simulation flow loop of Heat exchanger lalolala FLUENT 1 November 21, 2012 23:53
how to impose experimental dat as boundary conditi Rogerio Fernandes Brito FLUENT 14 November 25, 2008 05:47
