To find out convection heat transfer coefficient |
August 14, 2017, 02:15 |
Taiwan,new north city
Rep Power: 8 |
Can somebody explain the procedure to set the boundary condition to find out convection heat transfer coefficient (h) in fluent?
In my case i have solid body surrounded by Fluid domain. i need to findout convection heat transfer rate and h value. I already tried to find out the h value but i want to make sure that Fluent calculates the correct value of h. Thanks in Advance.... |
August 14, 2017, 18:42 |
Yang
Rep Power: 10 |
Make sure that the solid and fluid domain are NOT under the same part before meshing. Then, Fluent will generate two surfaces at the fluid/solid interface, one for the fluid, one for the solid. You should be able to use the coupled boundary condition at those two surfaces; Fluent will automatically calculate heat transfer b/w the two without you needing to specify heat transfer rate.
To get rate, after simulation: Reports (under Results) > surface integrals > report type: integral > field variable: wall fluxes and surface HX coefficient. I've never tried it though. Unfortunately, I'm having trouble with my interface too; my fixed temp fluid/solid simulation has a much thinner thermal boundary layer than just a fluid with one side at the same fixed temp. If you can help, I would appreciate it! coupled walls vs constant wall T Edit: nevermind, figured out why |
August 14, 2017, 23:34 |
Rep Power: 8 |
hello,
thanks for your suggestion. in my simulation i have done everything you said. i got the h value also. but i want to know after we create the interface for solid and fluid, where we need to set the temperature for solid. bcz if i set the coupled interface i cant able to set the temperature value for the solid body right? whether i need to use, 1.wall boundary condition with constant temperature and thickness or 2.convection boundary condition with free stream temperature only (i dont have h value) |
August 14, 2017, 23:39 |
Rep Power: 8 |
my suggestion for you,
1.i am wonder if you fixed you temperature there will not be any heat transfer bcz its already fixed. may be fluent will give you some temperature variation but i dont think its a good setup. 2. you can increase the wall thickness then you will get the thick boundary for the wall surface. you can see this option in wall boundary condition. its a conjugate heat transfer method. if you have any suggestion about my case plz let me know.. thanks in advance |
August 15, 2017, 22:30 |
#5 | |
Yang
Rep Power: 10 |
Coupled calculates temperatures for you (i.e. if you cook a pie in an oven and you know the air temperature in the oven but not the temperature at any place on/in the pie). |
August 15, 2017, 23:12 |
Rep Power: 8 |
i understood and i am also doing the same method. i just wanna make sure.
thanks for your reply. |
Heat transfer coefficient - what is waht | Stan | FLUENT | 28 | December 29, 2021 16:29 |
Hi i need to find wall temperature to calculate local heat transfer coefficient. i d | reslan | FLUENT | 1 | February 25, 2016 17:20 |
Porous domain:Interfacial area density and heat transfer coefficient | l.te | CFX | 2 | May 17, 2014 23:45 |
convection heat transfer coefficient | ehsanizad | CFX | 7 | February 7, 2014 05:06 |
about the convection heat transfer coefficient for air conditioning room simuation | haier1984 | Main CFD Forum | 0 | August 24, 2012 23:00 |
