superficial velocity
Like Tree2Likes
  • 1 Post By pUl|
  • 1 Post By chriss
Old   April 2, 2005, 05:48
Default superficial velocity
Taskin
hi,
I couldn't find what the exact difference between superficial velocity and physical velocity is. Fluent user guide 6.1 always defines it using porous medium, however my model do not consist of any porous medium. Moreover physical velocity condition gives a much better solution when compared to superficial. can anyone make a short description of their difference?
Thanks for any help
Taskin
Old   April 2, 2005, 15:18
Default Re: superficial velocity
ap
The superficial velocity in a monophasic flow is equal to its mean velocity, while in multiphase flows it's defined as the ratio of the velocity and the volume fraction of the considered phase in a multiphase system.
Best regards, ap
Old   April 3, 2005, 00:31
pUl|
ap is right. However, some people prefer to call it as the "Actual velocity" of a phase.
For Instance:
Actual velocity of gas phase = (Superficial velocity of gas phase) / (volume fraction of gas phase)
When you feed velocities and a guess for the volume fraction for a phase in fluent, you use the above equation to determine the 'Actual velocity' and enter this in the "Velocity inlet" panel. For the dispersed phase volume fraction you will have to enter the volume fraction guess that you used to calculate 'Actual velocity'.
Lennart.H likes this.
Old   April 3, 2005, 17:00
Taskin
hi, you mean in superficial velocity, it doesn't make a varying velocity distrubution along the cross section. It just takes a mean value, but physical velocity models the real situtation, I mean varying velocity distribution. did I understand correctly? Thanks for your help
Regards, Taskin
Old   April 4, 2005, 02:16
pUl|
Well, no. If you wish to specify a distribution profile for velocity across a boundary, you can either you ASCII profile definitions or UDF's to do it. Simply inserting values into the "Velocity inlet" panel just means a uniform constant distribution across the boundary, not a profile.
Old   April 5, 2005, 06:48
Taskin
hi, I mean, varying velocity distribution due to viscous effects. I give a constant velocity but, due to viscous effects, it should have a bell shaped profile after the flow is fully-developed. so is that what superficial velocity takes as a mean? Thanks for you help, Regards, Taskin
Old   April 5, 2005, 13:50
pUl|
Superficial velocity is simply a number (defined as):
Volumetric flow rate
Cross section area
Old   April 5, 2005, 15:41
Taskin
hmm I got it I think.. Thanks for your help Regards Taskin
Old   August 15, 2010, 15:10
Post superficial velocity
waqasiqbal is on a distinguished road
Superficial velocity is nothing but the velocity of a fluid in a pipe,conduit,column etc in the absence of packing or obstruction. like in packed columns the actual velocity of the fluid through it is actually the volumetric flow rate divided by the cross sectional area. so the velocity achieved by the same fluid in the same column in absence of the packing is called superficial velocity.
waqasiqbal is offline   Reply With Quote
Old   August 16, 2017, 14:22
chriss's Avatar
Christiano Santim
chriss is on a distinguished road
In single phase flows in absence of porous medium, the superficial velocity is Q/A, where Q is the volumetric flow rate and A refers to the cross-sectional area.
In multiphase flows, here assuming a gas-liquid two-phase flow, we have:
physical velocities...vg and vl
superficial velocities...Jg=alpha*vg and Jl=(1-alpha)*vl where alpha represents the void fraction and (1-alpha) is the liquid holdup, HL. Thus: alpha+HL=1.
Now, considering a gas-liquid two-phase flow in porous medium, we have:
First, defining the porosity as "por"......por=(V_total-V_solids)/V_total
So,
superficial velocities........vsg=por*alpha*vg and vsl=por*(1-alpha)*vl.
With kind regards,
Chris
masoud.ravan likes this.
C Santim
Chemical engineer
chrisoff22@yahoo.com.br
chriss is offline   Reply With Quote
UDF error - parabolic velocity profile - 3D turbine Zaqie Fluent UDF and Scheme Programming 9 June 25, 2016 19:08
how to compute relative velocity from absolute? spk Main CFD Forum 3 July 9, 2010 08:42
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
