September 7, 2017, 20:46 |
Fluent (High Lift Prediction workshop) error
Jose
Hello everyone
I'm currently doing a simulation (High Lift Prediction Workshop) of an airplane in landing configuration (flaps & slats). I'm using a semi-spheric mesh surrounding the plane as a pressure far-field (boundary condition) However, upon simulating I always get the same error code: Error: Cortex received a fatal signal (SEGMENTATION VIOLATION). Error Object: () Error: cx-enable-item: wta[1](Widget) Error Object: #f I'm using Spallart-Allmaras model with curvature correction. I've triple-checked everything in the simulation and haven't been able to find any errors. Does anyone know how to fix it? Many thanks |
Pressure outlet boundary condition | rolando | OpenFOAM Running, Solving & CFD | 62 | September 18, 2017 06:45 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 18:44 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
